#151 |
We did 12.5 again. That includes a bunch of driving in KS with a trailer too.
#152 |
Been watching this trailer. Likely the axles are bent from being overloaded.
http://www.ebay.com/itm/271435865890...84.m1423.l2648
#153 |
That looks like a good foundation.
#154 |
Its still at a good price.
#155 |
Monday was a busy day for the Big Gulp. Picked up a new trailer and a lawnmower. The trailer needs the brakes rewired and I am getting a set of matching wheels and tires soon. Also plan to put new LED lights on it. Will be hauling the minivan to Minnesota and a load of tools and shop items back.
I picked up the mower for $250. Runs and mows. Needs an oil leak fixed, new tires, and a new battery. We just got back from the car wash. Blasted all the grease and oil off so I can find the leak.
#156 |
Love the trailer.
Do you plan to flip the mower? What powers it?
#157 |
I plan to keep the mower. It has a 19hp Kawasaki twin. I think it is leaking where the two halves of the case comes together. Gasket failed. Will just replace all the seals and gaskets. New tires and a battery and it should be mowing.
I wish the trailer was slightly wider. Full size vehicles will be a tight fit.
#158 |
Gulp did 13.5 tonight. Most of those are local miles with about 100 miles towing the trailer.
#159 |
Not bad. Have you thought about changing the O2 sensors? Good quality units are cheap these days; even Bosch heated units run around the $40 mark, and they might step up your economy even more.
#160 |
I have thought about doing some tune up items. Changed an O2 sensor on the minivan and the mileage jumped 5 mpg. If I can pick up 1 mpg with Big Gulp it would be worth it.
www.rockauto.com. Great place for parts. I am going to pick up new rotors and pads for the minivan. I think I will get new O2 sensors for Big Gulp and a PCV valve. I don't want to touch the ignition system. It runs fine. If I blow another plug then we will go into that. The AC blows nice and cold out of the home depot irrigation covers they stuck into the ceiling vents. ![]() I do have a water leak in the back. I thought it was rain water, but it may be coming from the rear AC unit. Noticed today after I had it on that there was a puddle on the floor under the area. The drain may be plugged. No carpet in the back. It was really dirty and wet when I picked it up. Will be placing a horse stall mat back there.
#161 |
$43 for the upstream and $45 for the downstream. I already have the tool. Someplace.
#162 |
Is that a Bosch? I find that a couple of extra $ for the Bosch unit is worth it.
#163 |
That is for the motorcraft parts. I like to use OE stuff.
#164 |
Me too. You might find that Bosch is the OE. It typically is for Ford.
#165 |
It may be. Probably Motorcraft by Bosch.
