Old 05-01-2017, 11:25 AM   #166
Originally Posted by da4design View Post
got the mikuni today and installed it with a 110 main, last notch for the eclip, 1 3/4 turns out on the fuel mixture and runs better, i am sure i need to tune the fuel mixture a little but it is good for now
Move the clip up to the 4th notch down and see what happens. I've not had one run properly in the bottom notch.
Also, what pilot are you running? The stock 20 it came with? Those are fairly lean.
Do you still have stock exhaust?
Old 05-01-2017, 12:25 PM   #167
da4design   da4design is offline
da4design's Avatar
Yes I am using the stock pilot, I think I do need a fatter pilot. Looks like I need to order that next, I will try your suggestions, thanks! And yea still stock exhaust
Old 05-01-2017, 12:39 PM   #168
da4design's Avatar
What size pilot , in your experience works well with the 110 main jet?
Old 05-02-2017, 07:46 AM   #169
Kipper1012   Kipper1012 is offline
Kipper1012's Avatar
What size pilot did it come with ? did you get a real Mikuni or the china version ?
2016 Green Bashan Brozz.
Old 05-02-2017, 11:56 AM   #170
Just yesterday I ordered a 110/25 from jets-r-us for the same Mikuni (clone?) on my Rhino.
Old 05-02-2017, 04:06 PM   #171
da4design's Avatar
i have this, assume it is a clone http://www.ebay.com/itm/262202860867...%3AMEBIDX%3AIT
i have 110 main and the pilot is 20, i am gonna order an assortment of jets to learn with, and will need them if i decide to put on a better exhaust. thanks for the info guys, will order them today.
Old 05-03-2017, 06:10 AM   #172
BARLOW   BARLOW is offline
BARLOW's Avatar
i have a 115/40 ... runs good but a little rich at top end, but that should change with a new pipe and the cat out ... just got a new welder, so the cat will be gone soon
Old 05-03-2017, 09:44 AM   #173
Kipper1012's Avatar
cool thanks. I think im going the Mikuni route as well Mine boggs from idle when you blip the throttle and I cant find pilot jets for the Klehin that fit
Old 05-04-2017, 08:06 PM   #174
BigWeld   BigWeld is offline
BigWeld's Avatar
Quick update: I got my 5 cob led headlight bulb installed, and I couldn't be happier. The stock bulb had "35watt" stamped into it, and my led is rated for only 25watts, so there's a lesser "tax" on my charging system. Not only that, but after it was full on dark at my house, I flipped the key on and was pleasantly surprised by a CRAZY bright low beam, and an even better high beam. My next project is to dive into installing my light bars, and I fully plan on running them with a relay so they turn on with my high beam. Should be pretty crazy for night trail riding
Here's the Lo Beam:
Rides a 2016 Bashan 18C with Blue PlastiDip, piped and jetted, USB charger, real-time digital volt meter, faux carbon fiber handguards, 5 COB led headlight upgrade, auxiliary led light bars, and an MSR shift lever with new grips, T6 aluminum handlebars anodized in blue, polished handlebar brace, decals, HD Unibear chain and spoke covers waiting on the always-full mod shelf......
Old 05-04-2017, 08:33 PM   #175
MOTOXtreme   MOTOXtreme is offline
Right?? Ole Kipp didnt like the beam on his. Ive been very pleased with mine as well.
Brian
Previously owned / operated MOTO Xtreme selling American Lifan / Check out my friends at www.armattanquads.com
"Imagination is more important that knowledge" Albert Einstein
Old 05-04-2017, 09:58 PM   #176
Ariel Red Hunter's Avatar
None of this type carburetor respond well to "blipping". Although a Mikuni or Amal can sort of be made to do so. Try just rolling on the throttle while in gear and see if that works ok. The carburetors of this type can't pick up fuel fast enough if you just blip the throttle. There is only enough vacuum from idle to below 1/8th turn of the throttle to pull enough fuel up. Above that point, the fuel will start to catch up to the amount of air being admitted, but it takes an instant or two...ARH
Old 05-05-2017, 10:13 AM   #177
XDoubleXA   XDoubleXA is offline
XDoubleXA's Avatar
Here's the Lo Beam:
Hey, do you have a link for that? What all exactly did you have to do for install, just plug n' play?
Old 05-05-2017, 11:11 AM   #178
That's an impressive headlamp!...and smaller wattage? That's great. I may have to get a few of these.
Carb/jetting - I've had great luck with quick throttle response with all of my Mikuni's, once set up properly. That's the key. Proper jetting for your elevation both pilot and main, clip setting and proper setting of the idle mixture screw. Both the TT250 and Rhino react as quickly as any pumper carb I've had.
Old 05-05-2017, 12:19 PM   #179
Kipper1012's Avatar
Thank you for sharing all your experience !
So I guess mine is ok when I roll on the throttle it's fine. I've never messed with carbs I'm used to fuel injection
Old 05-05-2017, 12:58 PM   #180
Well, lucky you. You will find tuning a (for instance) Mikuni far easier than tuning (re-mapping) a fuel injection system. And a lot cheaper, too...ARH
