01-03-2019, 12:49 AM | #166 | |
For those of us who have bumped up our compression ratios and increased the specific output of the engine by 20-30%, heat is definitely an even greater consideration. Taller gearing also puts more load on the engine through each gear. This is coming from somebody that is more obsessive about maintenance and oil changes than probably anybody else here. My last Hawk's oil got changed more often than my underwear
01-03-2019, 01:23 AM | #167 | |
01-14-2019, 09:38 PM | #168 |
what effect would a oil cooler going into the screen port and also a oil cooler into the valve cover do vs two oil coolers to the screen port my guess is it would cause a better cooling effect ? and possibly better lubrication?
04 flywing 150 05 flywing 150 07 gasgas ec200 18 csc tt250 / foam filter mod, amazon exhaust, mikunki carb, 47tooth sprocket, o ring chain, stereo system, amsoil oil, honda 10w fork oil, tusk bars and brush guards.... more to come |
01-14-2019, 10:06 PM | #169 |
I considered that exact setup. The oil flow to the head comes straight from the pump and up the right rear head/cylinder stud to the valve cover anyway, so the difference would be fairly minimal. If you wanted the most direct cooling then it would be the way to go though.
01-15-2019, 11:13 AM | #170 |
I'm no rocket surgeon, but I have my concerns about running two coolers. It strikes me that there would be some loss in pressure with that much of an oil circuit, which the pump wasn't designed for. It may not be a concern at all, but I'd stick to one cooler.
01-15-2019, 11:23 AM | #171 |
I'm thinking about installing an oil pressure gauge. Not sure were would be the best place to take a reading from?? Bolt on top of valve cover maybe?
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 01-15-2019 at 11:55 AM. |
01-15-2019, 11:28 AM | #172 |
I’m looking on amazon for the same cooler. Do we need to add more oil to the engine to maintain the 50/50 level on the glass or just plug and play. Seems like increasing the volume of oil passing through is just what the doctor would have ordered for these motors.
Bashan Storm: Ebay steel exhaust wrapped, folding shift lever, seat mod, vm26 carb, air pod, dual led scrambler headlamps, windshield mod, led brake/tail light, secondary led brake light (swingarm), Ebay 295mm rear shock, back up CDI (racing unknown), oil cooler, digital gauge cluster, |
01-15-2019, 11:32 AM | #173 | |
01-15-2019, 11:43 AM | #174 |
Another +1 for the oil coolers then!
01-15-2019, 12:11 PM | #175 | |
My personal issue with the kits, specifically the sump system, is the length of the cooler lines. IMHO they are too long, especially considering they have to pump up hill already. Running a line length just long enough to get to the cooler and back will reduce flow restriction. This is an area where we have control over the pressure drop. For system pressure, the best place would be on the return side of the system before it goes back into the engine as close to the fitting as you could manage. This would be more indicative of the pressure the rest of the system is seeing as it is pumped through the engine after any potential pressure drop from traveling through the lines and cooler(s).
01-15-2019, 03:26 PM | #176 |
I questioned that too i wonder if theres an upgraded oil sump
01-15-2019, 03:48 PM | #177 |
I've been running the oil cooler for over a year and a half. I think if there was any kind of issue something would of happened by now. Oil must be flowing well enough as the oil temps hang around the 130-150 range which are on the low end. I think you guys in the northern part of the US where the temperatures get much colder would probably be better off with just a single cooler. Down south our winters are milder but summers are extremely hot. That's where the dual coolers really help.
I would like to install a oil pressure gauge just for a piece of mind.
01-15-2019, 05:34 PM | #178 |
Im more than likely sticking with just the one just was wondering what the difference between two coolers how you have it jerry or one cooler to the screen port and one cooler to the valve cover would be my judgement would be better localized cooling
01-15-2019, 05:46 PM | #179 |
I don't see why it wouldn't work any better. You would be cooling the oil before it reaches the head with the valve cover unit and then again with the screen port unit before it returns to the base. I'd say do it.
01-16-2019, 11:31 PM | #180 |
ive been thinking one oil cooler and one oil reservoir for additional oil. installed on fabricated engine guards. by the way those engine guards work well most of the time. i took an exit in gadsden in the pouring rain was carrying a little too much speed for conditions and was braking my harley ultra classic tank of a bike. well about mid curve hit a small repair bump and down we went. bike was sliding away from me as i was sliding and im looking thinking man those guards are great there doing their job well. then it slowed down enough for the tires to catch and flipped the bike to the other side and over past where the other guard would have helped. not too bad busted a latch and cracked the lid on the tour pak in five places two large scrapes on the front of the fairing and bent one light. got it off now and dismembering it to do the fiberglass work. light will bend back out and i got a new ring for the turn signal. i had tools everywhere across the road. clothes here and there. it was a sight.
