Old 02-20-2015, 08:30 PM   #2056
Originally Posted by FTEY View Post
The bolts/nuts does not look adjustable. Will take another one from the rear left and post soon.
Your forks are the same as the ones we will receive in North America. The forks with rebound adjustment are optional equipment. Thank you for taking the time to post the additional photograph.
Old 02-20-2015, 10:58 PM   #2057
FTEY   FTEY is offline
Left side of the rear wheel where the sprocket is. When you guys got your bike, please help to check the gas tank capacity. I know its speced as 16l but seem to be smaller than that.
Old 02-20-2015, 11:17 PM   #2058
FTEY,
Thank you for posting the additional photographs of the rear wheel.
I believe the fuel tank does hold 16 liters, but the fuel gauge is configured to show empty when 4 liters remain in the tank. This configuration is designed to protect the fuel pump for bikes that have fuel injection. If the fuel level goes below 4 liters, the fuel pump is not cooled by immersion in fuel, and it will overheat, shortening its lifespan.
Old 02-21-2015, 12:04 AM   #2059
Left side of the rear wheel where the sprocket is....
FTEY,
Can you obtain either a compass, or a pair of calipers?
If so, will you please obtain and post the following measurements for the rear sprocket?
Old 02-21-2015, 04:28 AM   #2060
Let me go and find...... Post soon....
Old 02-21-2015, 01:10 PM   #2061
thillskier   thillskier is offline
Banned
Ftey,
You MAY not have any luck with re getting factory and or dealer support re the carb issue. This is because in USA (not sure about regulations and or laws there in Maylasia of course, they can be fined $20,000 a DAY from the time they adjusted it to an out of federally approved spec (again in USA, especially California, (as their laws are even MORE complicated than Federal EPA's) until it gets adjusted back to original spec/settings.
Thats why its hard to get the bikes running right in USA unless they are fuel injected or you install a jet kit yourself. (which will put the carb and bike out of approved specification, BUT will run like its supposed to, AND give max HP that the engine was designed to make. It also will make the bike run longer since its not on the ragged edge, temperature wise (due to it running lean, from not getting enough fuel). This is also what causes the issues you are trying to work through, ie. running crappy, stalling, bogging and not developing hp and tq when throttle is turned as more air goes into the engine but less fuel than it needs is added to the air.
Its really not hard to rectify this and I'm sure I can help you do it correctly if we can get a "exploded carb view" so I can number/label the parts I'm wanting you to adjust and change. You can then pass the knowledge and proceedures on to your fellow bikers there in your area. ALL the bikes that are sold in that specification will have the same issues, until the fuel adjustments are tweaked. Also, I should add, its not buying a pre fettled jet kit. Basically, you will be doing that, actually developing/engineering yur own (and others) jet kits. You MAY want to take some notes on what you do and settings, jets, screw settings, etc., as you can then write the info down, buy parts needed for the next bike, and ship them the parts already tested and fettled (by you) saving the purchaser a LOT of time and taking the carb apart and reassembling. Most kits sell for 69 to 99.00 here, depending on if it a multi cylinder bike, and or parts needed to get it running as designed (right.
You WILL be an expert at carb assembly, and dissassembly before you finished figuring the exact settings out, BUT its not difficult, just time consuming, and depending on how much of a perfectionist you are, how much time is taken, also! You will REALLy enjoy how much better the bike runs and starts, also the POWER increase. Critically, at low speeds, when negotiating rocks, logs off road obstacles, is when you get the most benefits from this. The ability to get INSTANT response, and GOOD power and TQ to loft the front wheel, slide the back tire around, jump an obstacle, etc. can make the difference in a crash (and injury!) to you and or the bike, ve no surprises, and ride on away!
I can get an exploded carb diagram if you can't find one probably...it may not be the exact carb you're using (ours are EFI here, so I'd be guessing on which carb and its hook up etc. on your bike), but similar enough to allow you to get the job done, anyways. Ideally you get an exploded view of the carb on your model of cycle, of course...
Old 02-21-2015, 01:31 PM   #2062
The CSC Blog reports our Zongshen RX3 motorcycles are loaded on the Hanjin container vessel Germany, which is currently taking on more cargo in Pusan, South Korea.
Joe reports the vessel is scheduled to "arrive in Long Beach on the 6th of March. Due to the current labor unrest roiling our coast, the berthing date is currently scheduled to be on the 23rd of March."
Old 02-21-2015, 01:33 PM   #2063
A tentative, 5-year contract has been negotiated with the West Coast dockworkers.
Old 02-21-2015, 01:47 PM   #2064
I found this interesting, long video of someone riding his Minski TRX 300i. Starting around the 11:00 mark, I'm sure the rider wished he had mounted knobby tires.
Old 02-21-2015, 02:37 PM   #2065
Old 02-21-2015, 02:46 PM   #2066
Banned
Woo Hoo!! Yeesss
Spud,
Does this mean we will probably be getting unloaded when the boat gets berther (and I guess, as soon as our # is called after the backlogged boats are all unloaded?). If so, woo hoo!
So it looks like the IDEAL time frame of late April early May! Perfect weather, and, I hopefully will be DONE with these treatments !!!!!!
Really GREAT news Spud! Thanks for the updates!
Old 02-21-2015, 03:05 PM   #2067
Originally Posted by thillskier View Post
Spud,
Your guess is as good as mine. If I receive my RX3 in May, that is fine with me.
Old 02-21-2015, 04:48 PM   #2068
Banned
Sorry Spud:)
I forgot you don't have your "ESP" on today! hehe Its easy to forget that because you do seemingly know the answers to every question!
Old 02-21-2015, 06:30 PM   #2069
Old 02-21-2015, 06:40 PM   #2070
If one sticks with the 18-inch front wheel, the Pirelli MT21 is an excellent choice for a front tire. The MT21 is a perennial favorite with dual sport riders, and the size 110/80-18 tire is a good fit for the RX3 front wheel.
https://www.rockymountainatvmc.com/p...t-Rallycross?0
The size 130/90-17 tire is a also an excellent choice for the rear wheel.
