Old 07-27-2011, 03:21 PM   #196
katoranger's Avatar
This may help. Looks like honda change some things over the years of rebels.
http://www.rebel250.com/rebelforum/v...hp?f=2&t=18632
Old 07-27-2011, 03:22 PM   #197
TheRealWorld   TheRealWorld is offline
Thanks for the info. I will try to figure it out. I did have an email conversation with Mo, and he does not feel my diagnosis is correct. I just know that when I put the original back in, it fires on both cylinders.
Old 07-30-2011, 06:18 PM   #198
Oengus   Oengus is offline
I would order this unit
http://item.taobao.com/item.htm?id=5909088962
You can order it through this site they would need the link above to quote you a price.
http://taobaofocus.com/
Old 07-30-2011, 06:20 PM   #199
Or this one which is the one they use on the Johnny Pag bikes, but it cost twice as much.
http://item.taobao.com/item.htm?id=9828767747
Old 06-30-2012, 12:42 AM   #200
Been gone for a long time, been to dog gone busy! I have never been able to find a reliable CDI for this bike, the Hensim 250 Baja whatever. I have received several wrong ones and still have them. The original works until the ambient temp gets over 85. Then it starts to miss fire. Any of you got a reliable source for accurate parts. The ones I have received, look identical, but they are only for a one cylinder, I have two. It starts and runs, but only one cylinder fires. Runs good on the original when it is not hot.
Never did do any tranny work, I just baby it and get by.
Old 07-01-2012, 04:55 PM   #201
humanbeing's Avatar
The "generic" http://www.sanxin.com.cn/exhibit/exhview.asp?pid=8 can't fires 2 cylinder because it had smaller cap http://www.sanxin.com.cn/exhibit/exhview.asp?pid=13
If u can't finds the suitable one in states, buy via agents in China (There's successful story in Enduro board from a Australian guy)
The AC-CDi http://item.taobao.com/item.htm?id=13384067228 Made by http://www.cqlihua.com/
One of the invention by CHEAP roadside mechanic in bike's motherland that stocks Generic parts ONLY : a wire that shares the SAME signal from Pickup coil & 2 "generic" DC-CDI (the bigger that had extra red wire) to each ignition coil :wink:
Old 07-01-2012, 06:06 PM   #202
Hey, thanks for the reply, but those links are in Chinese and I can't make sense of them.
Old 07-01-2012, 08:54 PM   #203
humanbeing's Avatar
Originally Posted by TheRealWorld
... can't make sense of them.
Google Chrome's "auto translate" will gives u some idea.
btw Chinese isn't that hard . You can guess by appearance 并 (side by side) 列 双 (dual) 缸 as that picture in AC-CDI.
http://www.nciku.com is a good site for non-computerized materials. "Draw" it & get the result .
Old 07-01-2012, 09:17 PM   #204
Thanks, I appreciate your help and will try to work to figure it out.
Old 07-02-2012, 04:13 AM   #205
SilveradoSS   SilveradoSS is offline
I have ordered many parts for my Baja Phoenix 250 from the net. There are several sites that stock parts for them. What you have to do is search by engine code (253fmm) when you're looking for engine parts. Also Google for Honda Rebel 250 parts. The engine is a clone of the Rebel 250 engine. This engine was also used in the Honda Nighthawk 250. You can also google Baja Phoenix PX250. Another bike that shares this engine is the Jinlun JL250P.
Below are some sites that I've personally used:
http://www.scrappydogscooters.com/25...0_Twin_4T.html
http://search.store.yahoo.net/yhst-9...=px250&x=0&y=0
http://www.mastertechsports.com/cube...wCat&Submit=Go
http://www.m-and-d.com/results_sql.h...x250&x=18&y=12
Here are a couple of pdf files with parts breakout. One is for VIN prefix LE8P and the other for VIN prefix LUAH. You can google the part number corresponding to the diagram for whichever bike you have.
http://manuals.monsterscooterparts.c...refix-LUAH.pdf
http://manuals.monsterscooterparts.c...refix-LE8P.pdf
Also check for Hensim HS250CR parts.
http://www.partsyahoo.com/FYM-PX250-Cruise-s/128.htm
http://www.super-pocket-bike-scooter...ROAD_BIKE.html
I have modified my Baja PX250 by hacking off the restrictive mufflers and adding 12" Emgo slip-ons, added a Emgo pod filter in place of the airbox, rejetted from a 98 to a 137.5 main jet and replaced the stock 32 tooth rear sprocket with a Honda Rebel 30 tooth. My stock speed was ~70mph. After the mods, top speed is ~87mph. I'm currently down for a blown head gasket. I have the gasket set, just gotta make time to replace them.
Old 07-02-2012, 04:33 AM   #206
Like katoranger mentioned earlier with the link to the Rebel forum, Honda changed the wiring of later Rebels where one wire from the cdi goes to a kick-stand safety interlock. All you have to do on your bike is clip the non-firing cylinder cdi-to-coil wire and splice it into the wire going to the firing cdi-to-coil wire. Tape off the unused output from the cdi. It will not be used. This will have the bike firing both cylinders simultaneously, albeit on different strokes. There are two separate firing events for both cylinders, one is wasted during the exhaust stroke while the other is on the ignition stroke. Mine is set up this way with no issues. Well, except for the blown head gasket! Ha!
Old 07-13-2012, 07:04 PM   #207
I know everyone knows this but do I check the oil level with the dip stick in all the way or sitting on the opening? I am referring to my Hensim Baja
Old 07-13-2012, 07:38 PM   #208
All Hondas and Honda clones I'm aware of you check it without screwing the dipstick in. :wink:
Old 07-13-2012, 09:36 PM   #209
Thanks for the info, I found it low today, and thought maybe that is where is was supposed to be. Now I have to figure out why it is low. Good to hear from you again!
Old 07-19-2012, 12:32 AM   #210
OK finally got a new correct CDI and it works! I also have the proper oil level thanks to Doc. I do have one problem that is my fault. I left old gas in this unit since last summer and it sat in the carburetor, and now I have a running issue. It will start, but I cant give it fuel or it will kill. I need to choke it and leave the choke on and it starts up no problem, fires on both cylinders, but if I try to accelerate the throttle, it kills. When I restart it runs great for one second and then slows down to a slow idol.
I assume my problem is a gummed up carb, if I am right, how do I clean it? I have drained all the old gas, and the float is not stuck, as I can drain gas by opening the drain screw.
