08-30-2011, 01:56 PM | #196 | |
08-30-2011, 01:58 PM | #197 |
So, to bring everything up to date:
This is an email that I sent to Massimo, who forwarded it to Jessie at Yingang: Here is an update on the major parts of my bike that have not or do not work on my bike: • Tachometer - this morning the indicator fell, off, but it has never worked, I have attached a picture. • Speedometer - The hub on the wheel was messed-up and the "fingers" bent, above 60KM/H the needle moves backwards instead of giving the correct KP/H. I have attached a picture. • Never had a battery strap, made on out of zip-ties. I would like to get replacements for these 3 items. On the minor side: • Headlamp went out - ordered and replaced bulb ($6). • Brake light went out - replaced bulb ($5). • Turn signals quit working, replaced with electronic flasher ($9). • Side kick-stand was missing nut, caused bike to fall over, scratched up all of the guards on the left side. • Tank was missing bolt (replaced). • The racks were missing bolts (replaced). • The seat had the wrong bolt in it, I replaced it with a correct one (replaced). • Gas gauge quit working, but I re-set the ground, it now works correctly. • Chrome exhaust is blueing terribly around the catalytic converter, would be nice if the exhaust were black. I have almost 900 kilometers on the bike and enjoy riding it very much. Lots of people seem interested in it. I understand there is a dealer in Newnan, Ga that now carries Yingang bikes. Would be more enjoyable if the Tach and Speedo actually worked correctly. :( That was yesterday, today Jessie emailed me back from Yingang and they are sending out replacements for the guage cluster, the speedo drive and the battery strap. Much better that I expected, very impressed! Thanks Massimo and Yingang! Now if I could get my hands on the black exhaust with the heat shields.... |
08-30-2011, 02:01 PM | #198 | ||
08-30-2011, 02:20 PM | #199 | |||
I'm sorry to report many Chinese motorcycles have quality control issues involving loose hardware. :roll: Nevertheless, I still think you got a pretty good deal on a nice motorcycle! Thank you for reporting the good customer service from Yingang. Spud
08-30-2011, 02:53 PM | #200 |
>Spud - Thanks! I expected a few issues going in. Did not expect such a quick reply on replacements.
It is a good bike as a commuter. The saddle bags hold what I need them to. It is comfortable. Once I get ALL of the issues corrected (including the lean condition and a taller gear), I'll take it on a longer ride! |
08-30-2011, 02:56 PM | #201 |
It'll be great once it's all dialed in. It's my position that our Chinese friends do the rough-in, and we do the details.
08-30-2011, 03:20 PM | #202 | |
08-30-2011, 07:55 PM | #203 | |
08-31-2011, 09:33 PM | #204 | |
09-01-2011, 10:48 AM | #205 | ||
http://smfcycles.com/shop/ Which ones are you considering? |
09-02-2011, 02:59 PM | #206 |
Yingang YG200-2F,MSD200,MSD200B,MSD-35
I really like the Q link XP200.I was trying to buy Barnone's XF200,but things got pushed back and then I had auto repairs come up.I'm a Suzuki lover, so that along with the XP200's 18/21 tire combo, really got me liking it.I've got four street bikes.I'm ready for a on/off road bike to explore some of these gravel roads around me. |
09-06-2011, 09:11 AM | #207 |
They advertise that bike with a 163FML, if you go to the Yingang site and check the engine specs, you see it is actually a 205 version. With a 63.5x65 bore and stroke, the cubage is actually almost 206cc.
They rate it with 11.5kw @8000rpm that’s 15.65hp. That’s not bad. Yingang also has a 169FML that is an over head cam that has 16.32hp @9500 rpm. Its only a 198cc a bit smaller but also bit more powerful. http://www.yingangmotor.com/product/...ail.aspx?id=23 If you like these bikes, your in luck it seems they are importing allot of them, in a variety of models and most with the 163FML also two models with the 170mm, that is a powerful 250cc with nearly 26hp. (NX250) Get the model codes and google them it is the best way to find them…..http://www.yingangusa.com/ |
09-06-2011, 04:47 PM | #208 |
Thanks for the info.
09-08-2011, 09:24 AM | #209 |
So the saga continues...
• Blinkers and Brake light quit again. The flasher was broken, when shaken in rattled. Had my Father-in-law check for shorts, but everything was good. Replaced the brake light and the flasher. He had an idea to mount the flasher in foam, so I got a dense piece of packing and we drilled a hole into it and mounted it under the seat (you can see the original mount at the bottom): Seems to be working fine, but my brake light quit again this morning...considering an 1157 or equivalent LED bulb that might withstand the vibes. Also, I had to remove the front brush guard.. the weld at the top came apart and the metal braces on it came off. I re-welded it and am in the process of repainting. I'll post pics on this later. |
09-08-2011, 09:55 AM | #210 |
That foam mount is an excellent idea. Have you considered an LED tail light? I picked one up for just a few dollars on eBay, including shipping. I mount items like that with rubber plumbing washers between the part and the frame for a little cushion.
