#2191 | |
The 19-inch wheel kits will be available to order with the bike. We'll post a price shortly. We are prepared to grow and we are very excited about this motorcycle. It's one of the coolest projects I've ever been involved with. |
#2192 | |
Honda CB300R ABS |
#2193 |
Banned
Amen on the great buying experience!
I mean, for example, look at this THREAD!! WOW!!
There is a LOT of interest in this bike for sure! My feeling, honestly, is there are a WHOLE LOT of fence sitters out there that as soon as we take delivery, ride some distances, and post up in here the bikes area "as advertised", the dam will break on sales, Joe. I seriously believe that, and thatmmanaging the groth will be your biggest obstacle long run, for success. If I knew the "whole story" I might not be concerned at all. Rapid growth can be very difficult to grow with, IMHO (and in my businesses I('ve) own(ed). The honesty re everyone and everything to do with the bike (and ownership, maintainance w/o dealers, etc, ALL are very refreshing, to me. Thanks a LOT, Joe, and everyone at CSC. Also, Thank you also, Quadz and Spud, for an excellent forum, and "voice" for all things RX-3. GREAT job, guys. Seriously. |
#2194 | |
#2195 |
CSCDude,
I like your avatar. ![]()
#2196 | |
http://nuetech.com/tubliss/#sthash.VG4xZUWd.dpbs ![]() However, I much prefer using inner tubes, so I am not going to switch to the TuBliss system. ![]()
#2197 |
Three hours ago the Hanjin Germany was sailing northeast at 14.5 knots. The vessel was offshore the Kuril island of Urup.
![]() Yesterday, a 4.6 magnitude earthquake occurred in this area. http://www.emsc-csem.org/Earthquake/....php?id=429118 The Germany is sailing along the Kurile Trench of the Pacific Ring of Fire, and is heading next for the Aleutian Trench. ![]() Here are some photographs of Urup, courtesy of Google Earth. ![]() ![]() ![]()
#2198 |
A few people have complained about the size and shape of the right side pannier. I think this pannier will make an excellent, large tool box. It can hold a spare inner tube and a nice, large tool kit. In addition, it's a good place to stash snacks and your rain gear.
#2199 | |
#2200 |
Now that I can see the inside of the right pannier, its less going to be much than the 18.5 liters I guesstimated based on Joe's exterior measurements. And I see why Joe did not attempt to figure the interior volume of the stock luggage: too many bends and indentations.
I should wait until I get my RX-3 and see how I use it before making a luggage purchase. Still, presuming I will stick with the stock hard luggage, I am surfing options for a duffle to strap on the seat, and use for light camping trips. Right now the medium Nelson Rigg Survivor tail bag looks possible. About 40 liters, waterproof, about $60 with shipping, and its available in an orange color that might/might go with the RX-3 orange/yellow color option. |
#2201 |
I plan on keeping both side plastic side boxes. I will change the top box to the Givi Trekker 52L box (if compatible).
#2202 |
perhaps this gives an idea of space . Size 9 (US) boot I can get the other one in upside down and shut the lid.
With the pannier next to the exhaust it might keep your fish & chips warm on the way home ![]() ![]() Have been trying to get the torque settings together in one place but the different manuals quite often have different torques for the same thing.This is what I've got so far. Code:
******************************************************************** RX3 INFO AND TORQUE SETTINGS 1a ************************************************************************* ******************************************************************** NO GUARANTEE OF ACCURACY, USE AT OWN RISK !! ***************************************************** --------------------------------------------------------------------------------------- Some sources stated different torque values so an alternative torque is given ------------------------------katflap-------------------------------------------------- Headlight bulb HS1 35/35w Tyres ------ Front 100/90-18 225 kpa (32.6 psi) Rear 130/90-15 250 kpa (36.2 psi) Chain slack 10mm - 25mm (alternative slack 15mm-25mm) Coolant level The level of coolant is correct when it is at the bottom of the filler neck (alternative, 5mm below the top) Engine ZS177MM-P Idle 1500 ± 100 RPM Valve clearance INLET – 0,05mm / EXHAUST – 0,08mm (alternative 0.04mm to 0.06mm inlet & exhaust) Engine oil SJ 5W/40 (alternative 10w/40) Spark plug CHAMPION RG6YC or NGK CR8E 0.6 - 0.7 mm Torque 11Nm (8.1 ftlbs) Engine oil drain plug (M14) 25Nm (18.4 ftlbs) (alternative 15Nm , 11 ftlbs) Main oil filter cover bolts (M5) 8 Nm (5.9 ftlbs) (alternative 10.8Nm 8 ftlbs / 12Nm , 8.8 ftlbs / 17.5Nm , 12.9 ftlbs) Oil strainer plug left crankcase (M20) 13.5Nm (10 lbsft) (alternative 10nm , 7.3 ftlbs) Oil strainer plug right crankcase (M20) 13.5Nm (10 lbsft) (alternative 10nm , 7.3 ftlbs) sprocket cover bolts 16.2Nm (12 ftlbs) sprocket bolt 48.6Nm (36 ftlbs) (alternative 55Nm , 40.5 ftlbs) Ignition (generator) cover bolt (M6) 10Nm (7.4 ftlbs) clutch cover bolts (M6) 10.8Nm (8 ftlbs) water pump bolts 9.4Nm (7 ftlbs) Inlet duct (manifold) (M6) 10Nm (7.4 ftlbs) Exhaust nut (m8) 20.2Nm (15 ftlbs) (alternative 13Nm , 9.6 ftlbs) Crankcase bolt (M6) 10Nm (7.4 ftlbs) Gearshift pedal bolt (M6) 10Nm (7.4 ftlbs) Cylinder head bolt 38Nm (28 ftlbs) Cylinder head bolt (M6) 10Nm (7.4 ftlbs) Cylinder bolt (M10) 50nm (36.9 ftlbs) Rotor nut (M14) 80-90Nm (59-66.3 ftlbs) Primary nut (M18) 110 Nm (81 ftlbs) Clutch spring bolts (M5) 8Nm (5.9 ftlbs) Balance shaft nut (M16) 80-90Nm (59-66.3 ftlbs) Crankshaft nut (M24) 80-90Nm (59-66.3 ftlbs) Locknut of main pipe (M24) 25~35Nm (18.4-25.8 ftlbs) Fixed bolt of handlebar (M10) 50~60Nm (36.9-44.2 ftlbs) handle bar clamp bolts (hex head M8) 28~32Nm (20.6-23.6 ftlbs) Front axle nut (M14) 70~80Nm (51.6-59.0 ftlbs) Front axle flange bolts (clamp) (M8) 18~25Nm (13.3-18.4 ftlbs) Rear axle nut (M14) 70~80Nm (51.6-59.0 ftlbs) Engine suspension bolt (M10) 45~55Nm (33.2-40.5 ftlbs) Fixed nut of rear shock absorber (M10) 45~55Nm (33.2-40.5 ftlbs) Locknut of chain wheel (M8) 28~32Nm (20.6-23.6 ftlbs) Nut of rear rocker arm (M12) 50~60Nm (36.9-44.2 ftlbs) fork shaft nut (M12) 55~65Nm (40.5-47.9 ftlbs) fork shaft nut (M10) 45~55Nm (33.2-40.5 ftlbs) Engine mount (top) 35Nm (26 ftlbs) engine mount (middle) 40.5Nm (30 ftlbs) engine mount (low ) 40.5Nm (30 ftlbs) Pannier & top box frame and pannier boxes M8×85 M8x80 M8x60 M8x40 M8x35 M8×20 M6×35 M6×20 18~25Nm (13.3-18.4 ftlbs) Front protection bars M8×50 M8×45 M8×16 18~25Nm (13.3-18.4 ftlbs) |
#2203 |
Banned
Where to purchase?
Nelson Rigg bag, Nova? Seems like a bargain for that size at $60.00, also
#2204 | |
#2205 |
I might be interested in pannier take-offs, in case someone out there chooses to upgrade to something else. I'll continue to use my JC Whitney trunk.
