11-12-2018, 02:27 PM | #16 |
Glad to see there are more options now. Was really pissed that i missed out on the Brozz. But this looks to be the perfect replacement, especially with the right sized tires from the start.
It is hard to tell, but does this have a drum or disc rear brake? I actually preferred the drum on the Brozz as the brake actuator didn't stick down like it did on the Hawk 250. Where did you purchase this one? Is it the same motor as the Hawk 250? As one website claims it is a Zongshen motor. |
11-12-2018, 04:19 PM | #17 | |
11-12-2018, 04:23 PM | #18 |
Half the parts on that bike are on my Bashan Storm, could you show the speedometer, and does it have a gas gauge?
11-12-2018, 04:28 PM | #19 | |
11-12-2018, 06:50 PM | #20 |
Yes, I agree. We took brake cleaner to both front and rear before installing the calipers.
11-12-2018, 07:13 PM | #21 | |
My husband found a good video of a guy lowering the seat by cutting out some of the foam. That youtube is here: I was really nervous, but I knew I had to give it a try. I did the cutting last night, and took about 2-1/2 inches out of the foam. I wasn't as smooth as the guy on the video, so I've got to spend some time shaping it tonight. I'm hoping to get the cover reinstalled tomorrow or Wednesday. I'm really using baby steps on this, because I don't want to screw it up. We tested it last night in its rough uncovered form, and it really made a difference. I'm comfortably on the balls of my feet now, with my heels about an inch off the floor. I'm fine with that - it feels comfortable and in control. I have no idea how tall your son is, but I'm about 5'7", and have a 31.5" inseam. When I get it put back together, I'll post a photo. I really like your idea about the build being a good Dad-Son project, and I couldn't agree more. You two will have a blast! I'll let you know my results as soon as I get it finished. Don't hit the panic button quite yet! |
11-12-2018, 07:39 PM | #22 | |
I am almost certain it is a Zongshen motor. I'm sure I saw that name somewhere on the innards of the bike after we had it pretty much taken apart, but I can't find it now that everything is put back together. |
11-12-2018, 07:48 PM | #23 |
I don’t get why the stick with the low HP spec CG motors, no Chinese bike has that motor here anymore unless a farmer bike.
The better spec motor wouldn’t cost a few pennies more. Air cooled OHC 249cc or the 232.6cc much better power out of the crate and lucky it might cost $20 extra at the factory. |
11-12-2018, 08:00 PM | #24 | |
No, there's no gas guage. We checked, and there's no sending plate and no float in the tank, so it's not set up for a future mod. There's a Neutral indicator, and a nice gear indicator. Anything else you're curious about, just ask. Thanks again for the videos, we've learned a lot, and really enjoy them! [IMG][/IMG] |
11-12-2018, 08:03 PM | #25 | |
The BMS site itself states the Zongshen engine, although on the EPA/DOT certificate, it lists the engine manufacturer as Bashan. TMEC states the same thing, but also uses Zongshen engines as their OEM, so my guess is in some way, since the engines are proprietary to the respective brands, they can list themselves as manufacturer?
11-12-2018, 08:11 PM | #26 |
I had this some years back in China
17 inch wheels both ends 200cc CG motor They are a tall framed bike. Worked ok and got me around but oddball for body parts and front hub here I suggest high quality copper sibtered brake pads as these are just a common pad you could get from EBC |
11-12-2018, 08:17 PM | #27 |
What we've done for setup
Thanks to our months of lurking here, we learned some of the things we should do when setting up the bikes. Before we started installing stuff, we did the following:
We still have a few things to do, but they all need to be done out in the garage. (I've got to admit, we're not ready to move them out of the house quite yet!) It's supposed to warm up to almost 40 degrees on Wednesday, so we'll do the rest of the list then:
So looking forward to that last one! |
11-12-2018, 10:35 PM | #28 | |
11-12-2018, 11:26 PM | #29 | |
Also regulations they may need to do testing for plates and riad legsl Keeping quite is easier for them Or just buy the bigger cc power plant n do it your self but that’s not cheap doing it the long way round |
11-13-2018, 01:17 AM | #30 | |
