08-07-2009, 01:03 PM | #16 | ||
08-07-2009, 01:11 PM | #17 |
Did you check that throttle cable in "spare parts" bag? It might be a different length. Also, I found mine was pretty tightly packed in with the wiring harness. I re-routed so that it was free and then zapped strapped it to the frame. Although I am talking about the original cable/carb so the mikuni carb/throttle cable might be different.
08-07-2009, 02:46 PM | #18 |
Maybe I could try lube. I already tried unscrewing it weldandgrind. It did make a difference but the slider does not go all the way up. In the old carb the slider wouild go all the way up. I could maybe extend the cable or something.
08-07-2009, 03:06 PM | #19 |
It's not likely to be the cable length that's the problem. It's more likely to be the thumb throttle.
To prove it, you could remove the slider and remove the cable from the thumb throttle. Then, pull the cable manually to see if the slider extends all of the way; if it does, the cable length is fine. See if the thumb throttle can be modified to pull the cable further. Don't forget that the thumb throttle has a limiting screw for beginners. Since you're not a beginner, you could remove the screw completely.
08-07-2009, 03:13 PM | #20 | |
Some of the kids were horsing around with the quads when shut off, and pulled one of them right out, when I took it for a spin it was noticeably more aggressive! |
08-07-2009, 05:26 PM | #21 |
I'm not getting any spark. Fuel & battery seem good. I tried grounding the spark to the frame, no arc. Starter?
08-07-2009, 05:47 PM | #22 |
Check to make sure the boot is on the kill switch properly at the back of the unit. They are needly and if it's tipped a little it won't start.
Make sure all the switches are on as well. There is one on the handlebar and they key. Let me know there are other things you can check. |
08-07-2009, 07:49 PM | #23 |
Checked those things TurboT, all good. The battery is suspicious though. When it turns (attempts) to turn over it's like it doesn't have enough cranking power if that makes any sense. It won't full cycle, then after a couple attmepts basically nothing unless it sits for a while. Lights come on but I doubt they draw very much power. I'm going to pick up a trickle charger from Crappy Tire tomorrow and let it charge for a while. I see gio is out of stock. I'm thinking if was the starter or other electrical I woudn't get any turning at all. I could be wrong. I'll start with the battery first.
08-07-2009, 08:33 PM | #24 |
A trickle charge can't hurt. If it's turning over the starter is likely fine.
You may want to have a look at your wiring connections as well. They can wiggle loose from the factory. Make sure they are pressed into the white plugs all the way, especially around the cdi and rectifier. I would also check to see if they look correctly wired/color wise. |
08-07-2009, 08:57 PM | #25 |
Is the rectifier the part that has the spark plug wire attached to before the CDI? I figured out the CDI and traced all the cables back carefully the zap straps (I'll re-do those later) checking to make sure the white conections are fully connected. It has been starting the last 2 days, it took a few tries to fire it up but today nothing. I emailed John at GIO this morning but haven't heard back from him. If I'm not getting an arc from the sparkplug when I put it contact with the frame what are possibilities? You also mentioned checking the wire colours. If the wires are different colours wouldn't this be a problem from day one?
08-07-2009, 09:25 PM | #26 |
Maybe we can break this down a little.
You said "I'm not getting any spark. Fuel & battery seem good. I tried grounding the spark to the frame, no arc. Starter?" 1. When you say that the battery seems good, does that mean that the engine turns over at a proper speed? 2. When you tried grounding the spark plug to the frame, does that mean that you removed the plug from the head, plugged it into the wire and held it against the head while cranking? If the engine was turning over at this point, the starter is not the problem. I think that you've already established that, but I'm trying to clearly understand your concern. You then said "When it turns (attempts) to turn over it's like it doesn't have enough cranking power if that makes any sense. It won't full cycle, then after a couple attmepts basically nothing unless it sits for a while." 3. Is this a reference to cranking speed (in other words, does it only crank slowly)? I'm not sure what "it won't full cycle" means. 4. Have you changed the spark plug? The stock plug is junk. Switch to an NGK CR7HSA or similar; they're cheap. Don't worry about connections or components until you've properly charged the battery and changed the plug. That's a good starting point.
08-07-2009, 09:29 PM | #27 |
W&G makes great points and I don't want you to get ahead of yourself either.. I am curious if this unit has run already and just had this problem, or if this is out of the box like this?
08-07-2009, 09:38 PM | #28 | |||||
I think what I was referring to earlier is the ignition coil. I figured that out. Now I'm thinking stator after reading about them. The stator produces spark in the plug correct? How do I check it/test it? How do I access it? |
08-07-2009, 09:46 PM | #29 |
Has it run before or never started?
I wouldn't go replacing parts yet. Get a good charge on your battery. I would expect the frame is grounded, but not sure, I would check your spark on a head bolt or something on the motor just to be sure. I've had no spark issues with a 110cc Mini Hummer. It was one wire was pulled back from the white connection boxs that goes into the rectifier. (The rectifier changes current from D/C to A/C I believe) This is located up underneath the body kit screwed into the frame. There are many places for this to happen with the wires. You can also find the cdi box, and give it a squeeze to push the wires in. Sometimes they dangle loose from their resting place, swing and pull on the wires. |
08-07-2009, 09:59 PM | #30 | |
