#16 |
That is exacly where I told you to look, My loom is still OK but I can see the tape showing wear from rubbing against those metal parts that the lower part of the headlight bolts to. I do not do any off road riding as all my back roads are surfaced so perhaps it is the rapid handle bar movement that you get trail riding that speeded up the damage to your loom.
#17 | |
The loom is damaged because there was one layer of electrical tape in between a metal connector and that piece where you see the wear mark. The wiring is bad. That’s the bottom line. The wiring behind the headlight is not done properly. It needs to be reinforced if you don’t want to break down. It will happen to everyone at some point. It’s just not done correctly. They stop the conduit before the place that it rubs behind the headlight in the forks. Luckily, if you catch it before it shorts out, it’s a pretty quick fix. Even several wraps of electrical tape will buy you years of trouble free riding from that weak point.
2020 Lifan x-pect |
#18 |
Nothing wrong with the wiring, just the protection of the loom. That particular area is where a lot of movement of the loom takes place and will be prone to damage from friction
Now that this problem has been brought to light it is an easy fix that should be taken care of before it leads to breakdown. |
#19 | |
Now, what I’m not sure of is if this counts as a fatal flaw that ends my maintenance free x-pect experiment. What do you guys think? Should I call it a 2000 mile maintenance free run? Or should I break it down to electrical system lasted 2000 miles and keep an second tally for the engine and other powertrain type stuff?
2020 Lifan x-pect |
#20 |
Glad you didn't buy a new bike before you took a look! Ha Ha. The one I have is the same, if you turn all the way to the right it pulls it off the conduit to rest where you show the rub.
#21 | |
Maybe yours was a 2021 improvement. Ha ha
2020 Lifan x-pect |
#22 | |
Mucho thankso for calling this issue to our attention.
#23 |
And I just had a 3 hour off-road extravaganza with it!
Bike felt bad for being so crappy to me for so long and gave me the best ride I’ve ever had with it. I got 55mph slab for 10 mins, lots of exploring run down places, tight, twisty 2 track those UTV/side by sides could hardly get though, deep sugar sand, deep mud, open fields, thick woods, you name it! Best ride ever.
2020 Lifan x-pect |
#24 |
[QUOTE=david3921;370053]To be sure you should check around the steering head.
I feel like I have heard this before... ![]() |
#25 |
Good to see you got the 'chinks' (lol!) worked out. Electrical issues are sometimes a serious headache, but thank goodness it boiled down to a wire-rubbing issue...which should make everyone who rides these chinabikes...to perform an additional pre-flight inspection in addition to their normal prep! Keep on beating...down the trail!
#26 | |
I’ve put about 300 miles and 3 bike drops in deep sand on it now and still no problems.
2020 Lifan x-pect |
