#16 |
I hope you're ok after laying the bike down in gravel; road rash sucks.
Start by moving the clip down one notch, which will richen the mixture a bit at part throttle.
#17 |
Its super easy to change on these bikes, I think you have to remove the seat and prop up the gastank so the back is raised up., then unscrew the top of the carb and pull out the slide then remove the throttle cable. I would try raising the needle first (lowering the clip a notch)
Dune buggy build http://chinariders.net/modules.php?n...wtopic&t=14470 400cc lifan build vid: http://youtu.be/20HoU8OK_Y0 other fun: http://tinyurl.com/wildalaskan |
#18 |
Yes I am fine after going down I should have added that
![]() Moving the cclip seems easy I was thinking I would have to pull the carb off |
#19 |
Ok guys done the cclip mod took it out ran great noticed some slack in my chain so I pulled it in the garage set it up on a bucket to tighten the chain ended up falling off the bucket:/ I stood it back up finished what I was doing went to start it and the clutch lever snapped soooo since it will be down for a day or two time to do a few things spark plug,mod the air box and jet the carb who do you suggest I order the jets from the carb is sheng wey pd1
#20 |
I think Ive got a 110 somewhere if you want it
