Old 09-03-2012, 11:50 PM   #16
Originally Posted by Rameek
Yeah Manhattan can be dangerous. I was riding down there today in the village. Brooklyn is even worse.
I just received a new Killswitch but it doesnt work but the ignition does.
My fuse is blowing while I am riding which is terrible. I have no idea why its doing this.....
You must have an electrical short somewhere. :( I suggest you examine all your wiring and fix the electrical short, before it strands you in an unpleasant situation. 8O
So Spud I found out one of my issues. My Stator wire clips heated cooled and crumbled... horrible. The wires were grounding on the frame. I fixed it. Yeah I have been stranded a few times because of it.
I still cant find out why the killswitch dont work yet. The ignition switch works though weird.
I'm glad you found your electrical short, Rameek. Thanks for posting the update.
P.S. I agree with Weld regarding your malfunctioning kill switch.
Old 09-07-2012, 12:53 AM   #17
Rameek   Rameek is offline
The kill switch won't work because it's not completing the circuit to ground. While that sounds trite, it really is that simple. When you turn the kill switch off, you're actually connecting one terminal of the CDI to ground. Either the ground wire has broken, the wire to the CDI has broken or the switch simply isn't completing the circuit.
I will definitely investigate that. My brother and I just found some wire issues under the front light. Some of the ground wires that were soded together came off so we fixed it.
I did upgrade the CDI because the bike had a rev limiter but now I have to do a thorough investigation.
Its safe to assume that I have to open up all the wires that lead from the killswitch and CDI?
If you or anyone has any suggestions would be good.
Old 09-07-2012, 09:55 AM   #18
Before you go any further, did the repairs to the ground wires solve the problem?
Old 09-08-2012, 03:18 AM   #19
Everything is fully operational electrical and otherwise except the killswitch is still not working. Also I can turn the key to the off position pull it out and the bike will still run. WEIRD!
I fixed the wires under the light, fixed the stator connections, also suprisingly the battery was part of the issue. Now its just the kill switch.
So I have to rip the thing apart and find all the grounds.
I will take a picture of it tomorrow. I ride without side panels makes it look mean. This winter I will paint it a canary yellow.
Old 09-08-2012, 11:40 AM   #20
I think that there is a Kylon Fusion in the yellow you're after; it works really well on plastic.
If your kill switch and key switch won't shut the bike off, then there is still a ground wire that needs to be repaired (as you suspect). I would start by following the ground wire from the kill switch and see where it goes.
Old 05-03-2013, 05:53 PM   #21
I know its been quite a while. But I never got the kill switch quite fixed. But other than that it ran well.
Unfortunately I was in accident during the winter in Manhattan the only damage to myself I dislocated my finger snapped that bad boy back put guerrilla tape around the finger.
While I was out the country also someone hit the bike and it sustained additional damage. I just returned recently.
Now the bike will not turn over I will youtube it tomorrow to see if anyone has any suggestions.
The sad part is I had just purchased new tires, new rear brake, another muffler which I never put on (looking to mod a sport bike muffler), changed the gas tank from metal to plastic (which I was so happy about because had it still been metal it would have been utterly damaged),among some other products.
I have to replace all the fairings/plastics. Cant really fine them. But if I can get this puppy going. I think I want the shineray 200xyi plastics.
The lower arm the rubber ran out so we replaced the rubber where the long pipe went.
Wish me luck and if you have any suggestions on upgrades please do not hesitate to suggest.
Old 05-04-2013, 01:22 PM   #22
You snapped your finger back in by yourself? 8O
Old 05-04-2013, 03:05 PM   #23
Yeah I played football and did martial arts its kind of common place. It's painful and the worse part it was the clutch hand.
I always wear my TMS pads under garments and shell. This day I was in normal clothes because I rode to work so I was going to be careful.
Traffic was moving at a nice speed we had all green lights and traffic was cruising. A cab stopped short for a passenger and I couldnt stop in time and I tried to go from one lane to the other while trying to slow down. I clipped a hummer and lost that war.
I know if I was riding my brothers KLR 650 it would have been a worse and terrible situation.
Old 05-04-2013, 06:31 PM   #24
edtardo   edtardo is offline
edtardo's Avatar
This site has most of the hard to find parts for your bike. Also roketa DB-07 parts are interchangable
http://www.china-parts.co.uk/acatalo..._Explorer.html
http://www.china-parts.co.uk/acatalo...Body_Sets.html
http://www.roketa.com/product/produc...ID=0&proID=255
NewStar DB 200
Facts are meaningless. You could use facts to prove anything that's even remotely true! --Homer Simpson
Old 05-04-2013, 06:50 PM   #25
Www.runmasterusa.com is who distribute Kinroad in the US
Old 05-04-2013, 07:52 PM   #26
Originally Posted by edtardo
Yes I use china parts UK but the shipping is killer kind of a last resort type thing.
I wasnt sure which Roketa was the match thanks for that info.
If I'm not mistaken also the Zongshen bikes are also comparable.
Old 05-04-2013, 08:16 PM   #27
edtardo's Avatar
I know the zongshen diamo LS 200 is. I have some parts of all these bikes on mine.
NewStar DB 200
Old 08-26-2013, 03:44 PM   #28
Just a quick update. I was out the country for a little while and my brother and I decided to get the bike going again. After my small accident the engine wouldnt turnover. I decided to add all my new parts to the bike anyway since it was not working (All the parts I had sitting in my home before the accident). I met with Tvnacman (Dealer & Distributor thread) the engine is blown awesome man and website http://www.testedscooterparts.com/index.php. The bike sat for years and kind of was weathered. I will give the engine to Tvnacman and my brother and I will go to town on the wiring and some of the weathered parts.
Although I am in the process of purchasing another bike I am keeping this one. I love this bike. My only real complaint is the fairings. They are WAY to stiff no give and crack to easy. If anyone knows of better option let me know. I have to do a small modification to the gas tank fairing because the new plastic tank is slightly larger than the original metal gas tank.
Old 08-28-2013, 12:14 AM   #29
Thanks for posting the update. I'm glad you are not giving up on the bike.
Old 08-28-2013, 06:50 PM   #30
Oh hell no. I love this bike. In the city the ease and maneuverability is priceless. Definitely not a highway bike but city riding its PERFECT!
