#16 |
Thanx I'll contact them about the jets. Anyone ever done a big-bore on these motors? Want to make it a 250 if it is possible.
#17 |
Ref to CRF230F mods in 'net.
Raised piston kit http://item.taobao.com/item.htm?id=44359829884 maybe easier.
#18 |
Thnx
#19 | |
HB, do you know of a raised 69mm piston? I have a CB200 with a very short stroke, and I'd like to combine the 69mm piston with a long stroke (that I believe to be 66mm) to achieve 247cc. A raised piston would increase the power even more. Any thoughts?
#20 |
Did some work on the bike after I finished my studies
#21 | |
--- Water cool CB250-A http://item.taobao.com/item.htm?id=25090988818 fits the stock.
#22 |
I already have the crankshaft and the piston, but the rod is the wrong length. I might be able to use the rod from the stock crank.
Either that, or I'll just buy a CB223 upgrade kit.
#23 |
I rotated your pic for you.
Can you fabricate a new battery box, so you can use the pod filter?
#24 |
Thanx for the pic. Sorry didn't have a lot of time when I posted it. Yes pod just goes straight on the carb no probs with that. Was thinking of just glueing the old box and replacing the battery with a other one I have at my dads place. Only prob is now the back mudflap but I'll see what I can do about that. Does anyone no of any good replacement handlebars? Myne are bent to hell and back.
#25 |
Al bar of this http://item.taobao.com/item.htm?id=39936076991 style are popular in it's motherland
Ask in SA bike forum maybe better than from here, local knows availability/ price better than us.
#26 | |
Maybe you can help to support the fender with some black zip ties around the frame. What size are your bars at the clamp?
#27 | |
HB, do those risers adapt the bars from 7/8" to 1-1/8"?
#28 |
Firstly thank you for all the info. Should really tell you guys I have had 2 bikes before a Suzuki gs 500 and a Honda cx 500 but both were 100%. This bike I got from a friend in a really messed upstate. Back tyre is shot. Has no brake fluid. No chain ,busted airbox ,Alarm battery not a bike one ,handle bars there just not straight busted throttle cable and that about it that i know is wrong with it.
Now i found the cdi (I think) and its looking very weird to me. Ill load up the pics so you guys can see and tell me if its just me. When i got the bike it started but didn't idle and the choke had no effect at all. If its the wrong place to post this please tell me im still really new to the fourm. ![]() |
#29 |
Cdi's size & 1 black wire, i think it's a DC-cdi
=== http://translate.google.com/translat...niterCg125.php DC-CDI ![]() ![]() AC-CDI ![]() ![]()
#30 |
Yup.
Time to learn some chinese? Daily stuff isn't that hard, knows a few character will get the general idea. 注:原(orgin)车是细(small)把需(need)要加(add)装卡座才能安装.如果原车是变径把就是通用的直接换车把就是! ![]()
