Old 05-20-2015, 11:12 AM   #16
Originally Posted by No1Vic View Post
Probably wiser to use amber reflective tape on the side as a 'legal' jobsworth might argue white should only be shown at the front.... still amber will balance the reflector fitted to the front forks :-)
In my area, a vehicle (or trailer) that is viewed from the side must have amber at the front and red at the rear, allowing others to approximate the total vehicle length. When viewed from behind, the turn signals may be amber or red.
Old 05-20-2015, 11:12 AM   #17
Originally Posted by G19Tony View Post
I put a strip of reflective tape on the silver portion of the panniers. I tried to put tape on the bottom of the top box, but nothing would stick.
Perhaps an actual reflector that mounts with a stud and nut would be a good plan.
Old 05-20-2015, 02:37 PM   #18
No1Vic   No1Vic is offline
No1Vic's Avatar
Colour matched instead of silver panniers? Maybe a bit too much orange ;-)
2015 Honley RX3
2010 Suzuki 1250 Bandit
2006 Suzuki Hayabusa
Old 05-20-2015, 02:49 PM   #19
I did a similar photoshop image with orange, but I guess I just like basic black. However, I am going to add reflective tape to the center of the side panel on each pannier.
Old 05-20-2015, 06:02 PM   #20
oldqwerty   oldqwerty is offline
Hmmmm? The black does look better on an adventure bike than on a 'tater-whumper.
Maybe you can find some good retroreflective to match the paint at http://www.signwarehouse.com/
"Thou shall not Zong" is not a commandment.
Old 05-21-2015, 12:37 AM   #21
That shows real growth, OQ.
Old 05-21-2015, 05:57 AM   #22
No1Vic's Avatar
Now there's a thought oldqwerty, respray the bike in the same shade of orange but with a reflective base paint, how visible would that be at night......
2015 Honley RX3
Old 05-21-2015, 10:21 AM   #23
jimjr21   jimjr21 is offline
Most plastics have a mold release on them from manufacturing. Try acetone to clean the plastic and see if you can get something to stick (like tape) then apply reflective material.
Currently In the garage in various states of running (or not) order
2015 Rx-3 super speedy blue
2003 BMW F650GS
2001 H-D V-Rod
1999 Ducati 750SS
1997 Yamaha Riva
1995 KTM 250
1970 Honda CB350
1952 Ariel Square four
Old 05-21-2015, 10:48 AM   #24
JTHSPACE   JTHSPACE is offline
JTHSPACE's Avatar
You can, of course, get 3M Black Reflective Tape for the panniers; it reflects white at night, so legally (in the UK) it can only be used on the front and side of the vehicle.
Jeff
Riding bikes for over 40 years
Honda C50 / SS50 / CB125 / CB250
Velocettes (various)
Piaggio's / Honda's / Yamaha's
Raptor . . . . the List Goes On . . . .
Old 05-21-2015, 10:53 AM   #25
JTHSPACE's Avatar
You can get red and yellow small round reflectors with stud and nut with LED bulbs inside to act as side lights and/or indicators / tail-stop lights fitted to panniers, topbox, fairings etc. Really cheap on eBay.
Marker Lights
Jeff
Old 05-21-2015, 11:18 AM   #26
I'd try acetone in an inconspicuous place first, to ensure that it doesn't harm the plastic. You might be better off with lacquer thinner or alcohol.
Old 05-21-2015, 11:50 AM   #27
Acetone test
Acetone will continue to dissolve the plastic indefinitely. Minimal color change. Used a cloth towel and by rubbing the surface finish changed a lot. Much much smoother.
I will test more chemicals to see what cleans the best for basic sticker adhesion.
2003 BMW F650GS
2001 H-D V-Rod
1999 Ducati 750SS
1997 Yamaha Riva
1995 KTM 250
1970 Honda CB350
Old 05-21-2015, 02:30 PM   #28
rjmorel   rjmorel is offline
rjmorel's Avatar
Spud, I've been eyeballing them also but was going to paint just the "square X " a school bus yellow or sky blue to add more color . Would give the rear end more visibility and gives the caggers something to aim for )))))
Spud, how do you edit your pic to blacken out the silver? What program or software do you use? I'm smelling a coloring contest here to make a cool looking RX3.
I've been wanting to tiger stripe mine like the old Triumph Tigers from early 2000s.
rj
Old 05-21-2015, 04:05 PM   #29
Originally Posted by rjmorel View Post
...Spud, how do you edit your pic to blacken out the silver? What program or software do you use? I'm smelling a coloring contest here to make a cool looking RX3.
rj
I don't want to buy Photoshop, so I use a free program called Gimp 2.
Old 05-24-2015, 10:08 AM   #30
No1Vic's Avatar
Here you go Rjmorel....
2015 Honley RX3
