Old 08-14-2015, 10:56 AM   #16
dave92029   dave92029 is offline
Brie pad
My front brake is pulsating, so I need to contact Ryan to ask for a replacement.
Does the front brake pad need to be replaced at the same time? Wouldn't the Brake pad also have uneven wear due to the faulty rotor?
What is the recommended torque for the bolts? Why would I need to replace the bolts?
Thanks
Dave
Dave
Old 08-14-2015, 12:04 PM   #17
Installing the rotor bolts is not a problem. The problem arises while trying to remove the rotor bolts. The bolts are bathed in loctite at the factory, and probably installed with an impact driver. Therefore, it is very easy to strip the Allen key head, which can make the bolt very difficult, or impossible to remove without machine work.
Remove the bolts slowly, and with great caution, taking care not to strip the head. It is recommended to heat very troublesome bolts with a propane torch. After you successfully remove the bolts the first time, subsequent installation and removal of the bolts is an easy process.
Old 08-14-2015, 12:26 PM   #18
3banger   3banger is offline
3banger's Avatar
A number of us have reported brake pulsation. Has anybody made the run-out measurements with dail yet? I can feel the pedal of the rotors just be for coming to a hard stop but no pulsing at speed.
I really do need to find a more aggressive pad, I'm worried my ham fisted braking technique I've developed to stop the RX in a reasonable distance will end in desaster the first time a panic breaking situation arises in my Sprint.
Old 09-06-2015, 01:17 AM   #19
I didn't measure run-out with a dial indicator. However, I did measure the thickness of my old brake rotor with a micrometer, and I noticed numerous variances in thickness.
After doing some research, I concluded the front brake rotor has the same dimensions as many KTM brake rotors. The only difference is the RX3 brake rotor has larger bolt holes. If one wanted to insert helicoils in the front hub to accept smaller bolts, I'm sure he could switch over to the KTM brake rotor.
Old 09-06-2015, 01:30 AM   #20
pete   pete is offline
pete's Avatar
would it not be easyer to drill the KTM rotor for the bigger bolts ?
Or is that not possable ?
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 09-06-2015, 01:38 AM   #21
I think you are correct, Pete. Unfortunately, I don't own a drill press, neither do I own good drill bits for cutting hard steel.
Old 09-06-2015, 01:52 AM   #22
pete's Avatar
Ok.. theres 2 items for yer shoping list....
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
Old 09-06-2015, 02:15 AM   #23
Rather than drill the brake rotors every time, I would rather stick with Zongshen rotors, or install helicoils.
Old 09-06-2015, 02:58 AM   #24
pete's Avatar
how meany brake rotors do you intend to go though..?
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
Old 09-06-2015, 12:07 PM   #25
How many do you intend to use?
Old 09-08-2015, 01:05 AM   #26
rjmorel   rjmorel is offline
rjmorel's Avatar
Spud, I measured thickness on my pulsing front rotor also and found it to be about .005/in variance. Rear one was within .001". Bought a new rotor and surface ground the old one best I could and it made it usable with a very mini pulse feel to it. Keeping the new rotor for later. rj
Live Zong, and Prosper
Old 09-08-2015, 01:34 AM   #27
I'm fairly confident Zongshen does not manufacture brake rotors. I'm pretty sure Zongshen bought these brake rotors from another company, and assembled our shipment of RX3 motorcycles with a bad batch of rotors. Since CSC offers such excellent customer service, replacing a bad brake rotor under warranty is an easy task. Therefore, I am content to stick with the stock brake rotor, since it does a good job when it is within proper specifications.
Old 09-09-2015, 12:02 AM   #28
Jay In Milpitas's Avatar
Check your lever.
On the subject of brakes, I noticed that after my first ride the front smelled a bit hot. Since it was only a short, leisurely putt around the neighborhood I though that odd.
Close examination found that the front cylinder mount was too close to the throttle assembly and when released was hitting, not allowing full retraction of the master cylinder piston.
Quick little adjustment inboard prevented a possible heating/warping situation.
Old 09-09-2015, 01:39 AM   #29
That's a very good tip, Jay.
Old 10-23-2015, 01:49 PM   #30
Juanro   Juanro is offline
Juanro's Avatar
So, is there a replacement or compatible part number for the front brake pad?
