Old 08-19-2015, 10:30 AM   #16
Not surprised by the VS brake orientation.
Forum member AtomicWedgie is a CX fan and an avid cyclist also; he always switches the bicycle cables around to match a motorcycle.
Old 08-20-2015, 10:24 PM   #17
cheesy   cheesy is online now
cheesy's Avatar
Back from the road trip and spent a bit more time with the 3800.
Get the fork yanked and start to pull the caliper when I see this.
One arm of the caliper had broken off and the PO had done this. No wonder it didn't stop. A redneck repair if I've ever seen one. On the bright side, I can use a section of the 'repair' and weld it to the caliper arm the correct way.
Cheesy
07 Ural Gear Up
79 Honda CX500
77 VeloSolex 4600 V3
73 VeloSolex 3800
Old 08-21-2015, 12:34 AM   #18
It looks cobbled together to me, but I'm not exactly sure how it should look.
Old 08-21-2015, 08:33 AM   #19
cheesy's Avatar
Well, I just found out that I can get the caliper arm from France for 0.75 euro. Not even worth breaking out the welder for that.
http://www.solex-motobecane.com/3-fr...lex-149-80.htm
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 08-21-2015, 11:12 AM   #20
I'm interested in the replacement of the caliper arm. I can't visualize how the item you linked to will replace the redneck repair.
Old 08-21-2015, 09:28 PM   #21
cheesy's Avatar
The caliper is made up a boat load of stamped steel parts. Included are two right arms and two left arms. Each pair of arms holds a brake pad. What I have is one broken left arm.
My friend and coworker in France is picking me up two pairs of arms(among other small parts) and bringing them stateside for me next month.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 08-22-2015, 11:09 AM   #22
That's a terrific connection! I hope you also asked for something from the Bordeaux region.
Old 08-22-2015, 05:39 PM   #23
cheesy's Avatar
If it wasn't for Tony(and Christian, Neil, Mirko, Luc, Xavier, Alfredo, Jesus, and any of my other international co-workers)there probably would be no liquor in the house. I believe I got a bottle from the Alsace region and one from the Piedmont region earlier this year. The guys from Mexico brought me locally distilled mescal and tequila. The Brit brought me a bottle of Balveinie last year. I'm still waiting for the Canucks to pick up a bar tab, though. They're from Ontario, whatchagonnado?
I'm bringing Tony bottles from Illinois and Maine next month. Maybe he will still like me.
Bit more done on the 3800 today. New chain and freewheel installed, over hauled the bottom bracket plus drilled and tapped the same for a grease zerk so I don't need to take half the frame down to do it next time. Fork and wheels on. Plastic welded the cracked throttle tube. I have a new one on order but I want to see if this works.
Other than that, plodding right along.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 08-23-2015, 12:18 PM   #24
Have you checked out Moped Army? That might be another source for used parts.
Old 08-23-2015, 02:33 PM   #25
cheesy's Avatar
Yup, got my new headlight from them. Which, by the way, works. Still no tail or brake light but I'm narrowing it down. Finished up the bicycle part on the 3800 this morning and also tried my hand at plastic welding the cracked throttle tube. Man, I could have saved thirty bucks if it holds.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 08-23-2015, 08:15 PM   #26
Did you use the HF plastic welder?
Old 08-23-2015, 09:10 PM   #27
cheesy's Avatar
No, I got a cheap one from Menards'.
Got the 3800 back together tonight but that's as far as I got. Went to pull the flywheel, but my tool doesn't fit. I think I have one that will fit at the shop.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 08-23-2015, 10:53 PM   #28
Darkrider   Darkrider is offline
Just a tip for future plastic welding...a soldering iron works quite well for this as well!
Past bikes:
'10 Gio X33
'85 Honda VF750F Interceptor
'80 Honda XL185S
'76 Yamaha DT250C dual sport
Baja Wilderness Trail 250
'07 Honda Shadow 750 Areo Trike
'01 Harley Davidson Softail Deuce
Polaris Magnum 425 4x4
Originally Posted by andyj812 View Post
You can't pin this one on me, my wife is still mad at me. I don't need your wife mad at me too. LOL
Disclaimer: The above post by 2LZ is in no way the view of this site, other members or Bruce's llama. It is the opinion of 2LZ and 2LZ alone. ;-)
Old 08-24-2015, 11:00 AM   #29
It can, but the flat shoe of a plastic welding iron is much easier. I have a cheap one from HF that does a decent job. They also have an assorted bag of filler rods, with PP, PVC and ABS. Also cheap.
Old 08-25-2015, 10:13 PM   #30
cheesy's Avatar
Woohoo, spark and fire on the 3800 this evening.
Cleaned and reset the points, got spark. Shot some two stroke into the carb, flipped the flywheel a couple times and away it went. Ran about 10 seconds on what was in the carb and just purred. A stinky two stroke purr, but a purr nonetheless.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
