#16 | |
#17 |
Excellent idea, because a GM 10SI alternator can spin in either direction.
#18 | |
#19 | |
It runs off the output shaft of the transmission and is located in the hydraulic reservoir between the transmission and axle. This is referred to as non-live hydraulics. Same with the PTO. It only operates with the clutch out. Some tractors have a two stage clutch that will allow you to stop the tractor, but keep the PTO spinning.
#20 |
That must be the "PTO overrunning coupler" that I've read about.
Do you have plans to run a hydro pump off of the crank pulley?
#21 |
The overrunning couple attaching to the PTO and then you hook the shaft from the implement to it. It keeps the momentum of a spinning implement from acting on the tractor after the clutch is pressed. With a live PTO or 2 stage clutch this is not an issue.
I may install a belt driven pump later. That would be useful for operating hydraulic cylinders. In stock form it was only designed to lift the 3 point. The tractor does not have any hydraulic remote connections.
#22 | |
The 8n was on my shortlist when it came to getting a utility tractor. I ended up with with a small diesel Kubota with about the same capabilities as teh 8n. It's nowhere near as pretty as the old Fords, though. ![]()
Current: bikeless for now, moved into a campervan. Past: 2012 Honda NC700x, 2014 Taotao ATM-50-A1, 2014 Taotao Evo, 19?? Honda Spree 50, 1982 Katana 550 |
#23 |
I thought about 12 conversion on mine too. And I do have a alternator for it. Big deal is a 8n has a positive ground. So the starter needs help and a whole lot of it spinning the wrong direction with twice the voltage it was designed for.. The coil only needs a resistor. John
#24 | |
http://www.yesterdaystractors.com/articles/artint8.htm
#25 |
Great saved the link.
Thanks. Looking back when I was a kid an older kid who just got his first car an old maybe 48 chev or olds with the bathtub looking body, any way he got a new battery and put it in backwards and he said it started any way. smoked something doing it though. If that tractor starter will work next time I buy a battery it will be a 12 volt. Have had tractor 20 years and about all I get is 2 or 3 years per battery and there is only one parts house that still keeps 6 volt batteries around. john .................................................. .................................................. .................................................. .............. incidently I paid as I remember $1300 and it had 2 brand new rear rims (old owner used sodium in tires and it causes rust on rims) Also got an 8 ft blade with it and I had to buy 2 new front tires. |
#26 |
Son of Weldangrind changes tractor and transport truck tires for a living, and he told me that calcium chloride is the ticket for increased traction. There is a chart that shows the recommended ratio of CaC12 to water, from 32F to -62F.
#27 |
That is the reason for the new tires and rear rims on this tractor. I won't need it for my usage. The only area that I may need some additional traction would be garden plowing, but I think that I can get away without.
There is a newer product called rimguard. The rear tires on an 8N are somewhat large compared to modern utility tractors. That will help put all those 23 horses to the ground.
#28 |
Looks like I may go after it on Sunday afternoon. He is going to use it one last time tomorrow. Might take two trips to get all the implements also.
#29 |
Today is the day. I got a trailer load of implements last night.
#30 |
Yay! Pics?
