Old 03-21-2016, 12:18 AM   #16
mq1991   mq1991 is offline
Originally Posted by traygiddens View Post
just put the 17 on front and will put the 45 on later.
BUT, something which is a little concerning is there is a little bit of play in the front sprocket now , like the original was a little bit thicker than the aftermarket one. should this be a concern?
I dont think so, I think the way its designed is that the chain "auto centers" the sprocket. So as you ride the sprocket kind of automatically finds its center.
Mine was the same way.
I could be wrong though, hopefully its all good!
Old 03-21-2016, 07:48 AM   #17
SeerAtlas   SeerAtlas is offline
we have changed two hawks. neither had any play in front countershaft sprockets, either before or after...sure they sold you the right sprocket?
Seer's First LAW-"FLY THE PLANE!", fail that, and nothing else matters. 12th Law- Consider what marvels you might do if only you had tomorrow to live over again. Third Law-When someone tells you some thing "Can't Be Done", what they're really saying is They can't do it!!14th Law-Just because something "IS", doesn't necessarily mean it SHOULD be.. Eighth Law-The only true personal security is anonymity.Ninth Law-Humans tend to learn very little when speaking.10th Law-Some lives ARE worth taking
Old 03-21-2016, 09:48 AM   #18
chuck   chuck is offline
Mine have the same play too, I was concerned at first but it's been good no problems.
Old 03-21-2016, 10:21 AM   #19
traygiddens   traygiddens is offline
I had read someplace that the original sprocket is 20mm wide and the jt sprocket is 18mm wide. There is some side to side play but watching some vids about sprocket replacing on honda 250's this seems to be pretty standard.. Just checking with you all.
Old 03-21-2016, 10:32 AM   #20
Azhule   Azhule is offline
I recently changed the sprocket on my Kawasaki KLR650 to a 17t that normally went on the KLX600 (I think)... but during my research I found dozens of people reporting 'Leaks from the Shaft' showing up after several thousand miles of use (3 or 4k), and it was only on the motorcycle that DID NOT 'measure and shim' the sprocket(s).
Come to find out the 17t sprocket is 3mm or so smaller (width), those who put a few shims on with the sprocket had NO leaks from the same area, one guy reported having over 40k miles with a shimmed 17t and no leaks.
Good news, if you get a leak from that shaft, the gasket/o-ring is cheap to replace (even on a Kawasaki)
Old 03-21-2016, 03:30 PM   #21
Thanks
Old 03-23-2016, 10:39 AM   #22
countryborn   countryborn is offline
Hey y'all I'm new here. I just bought a rps hawk enduro from killer motor sports I read on here about sprocket changes so I figured hell I'll go will a 35 tooth gained 5 to 8 mph took my tip off the exhaust and gained 4mph changed my spark plug to a NGK and gained 4mph when I got the bike it was rapped out at 45mph after my changes it goes 62mph on the flat guna change the carb and air filter. See if I can get up to 75mph
Old 03-23-2016, 12:39 PM   #23
Welcome; we are glad you joined us.
Old 04-06-2016, 01:07 AM   #24
Entropy   Entropy is offline
So why is the part # for the rear sprocket JTR269 and the front JTF259? I did find a JTF269...which is the right front sprocket?
Old 04-06-2016, 11:32 AM   #25
JTF259 (the F is for front) is the correct countershaft sprocket, assuming you wish to retain the 428 chain pitch. I would.
JTR269 (the R is for rear) is the correct rear sprocket, assuming the bike has the standard Honda XL185 bolt pattern 428 sprocket.
There is no such sprocket as JTF269, according to http://www.jtsprockets.com/
Old 04-06-2016, 02:36 PM   #26
Ok, thanks Weld. I thought I found a 269 front on Google but you just confirmed I ordered the right one.
Old 04-06-2016, 11:27 PM   #27
Happy to help.
Old 06-01-2016, 01:46 PM   #28
kohburn   kohburn is offline
kohburn's Avatar
anyone tried a 17/47 combo?
the TT comes with 17/50 stock and I've only really seen people with either 17/50 or 17/45 combinations.
its only 20$ so might have to try it.
- 2008 Kawasaki Versys
- 2016 CSC TT250
Old 06-24-2016, 11:27 PM   #29
BPMT   BPMT is offline
Originally Posted by SeerAtlas View Post
wolf, i,m in the ozarks
mjstep- i am at about 1k elevation, presume u r in the clouds. i think u can find a 14 or maybe even a 13 front counter shaft sprocket which should get your first gear down near honda trail 90 type speeds you must be riding some gnarly chit! :}
I leave the garage at 3300 and can be 4700 with a whole lot of room to climb in 10 minutes.
