Old 04-12-2016, 01:04 PM   #16
BARLOW   BARLOW is offline
BARLOW's Avatar
jb weld a washer in the slot, or just use your thumbnail like i do ... lol
Old 04-21-2016, 07:54 PM   #17
blackhawkdown   blackhawkdown is offline
blackhawkdown's Avatar
Head Scratching please help
Hello fellow flock members! I am a hawk owner myself and am having tuning issues with the current carb + air filter setup so I am going to change it up and dial everything in legit. My airbox wasn't sealed well and my hot air return hose from the engine to box was torn as well so I am just going to overhaul the whole intake system. What model carb and brand did you all use??! I helped a buddy convert his stock dual carb banshee to a single keihin single setup so I know I can do this just need some of your help and its now been a year my hawk has been collecting dust though she has started for me twice and ran for a little both times so i know she has the will to fly just a matter of not giving up with these bikes!
part time handyman and full time rider.. i only have 2 years riding experience but ive fallen in love already and its kept me off the streets until now!
Old 04-21-2016, 10:34 PM   #18
Did your air box/hose connection look like this?
Old 04-21-2016, 10:38 PM   #19
farmbath   farmbath is offline
Mine sure does!
Old 04-21-2016, 10:45 PM   #20
Originally Posted by farmbath View Post
Mine sure does!
What model year of the Hawk did you purchase, and from whom did you purchase it?
Old 04-22-2016, 01:48 AM   #21
thanks for the quick replies brothers!!! and i bought the 2015 all black..she looked like that until i ripped that rubber tubing to the airbox off because the seal was so poor! Also there was a rubber hosing at the bottom of the airbox that was connected to what i think is the crank case and it was totally torn is that an important hose and what is its job to cool off the crankcase or engine?! It was connected to the airbag right under the big rubber pipe manifold that had the poor seal
Old 04-22-2016, 01:57 AM   #22
Azhule   Azhule is offline
I attached a PCV (Positive Crankcase Ventilation) Valve to mine when I removed/ditched the stock air filter and housing for an UNI Pod Filter.
I just went down to the local Auto Parts Stores with the Hose off the engine and found a PCV valve that fit.
Old 04-22-2016, 11:07 AM   #23
...Also there was a rubber hosing at the bottom of the airbox that was connected to what i think is the crank case and it was totally torn is that an important hose and what is its job to cool off the crankcase or engine?! It was connected to the airbag right under the big rubber pipe manifold that had the poor seal
Yes, the hose is important. The crankcase vents through that hose into the air box. I suggest you replace that hose, or you risk sucking dirt and/or moisture into the crankcase.
Old 04-22-2016, 12:43 PM   #24
Spud and Azhule you guys are awesome thanks for replying so quick. I knew it was important and no one mentioned what to do about it or seemed to know what I was talking about. Cant wait to post a pic and vid after I get the blackhawk airborne! I was discouraged about registering it in NY and putting much money into it aftermarket but after reading about the SD and VT title transfer option and hearing about the luck others have had with wr450s and yz250s Im sure Ill have no problem and I love my hawk again as much as the day I bought her on my Macbook haha! Gunna throw in a new carb, K&N clamp on filter, look into my crankcase ventilation options, and last but not least a high power L.E.D. or H.I.D. Halo headlight!! Ill post any updates and thanks agin for your help brothers
Old 04-22-2016, 08:19 PM   #25
faulknja   faulknja is offline
I finally received the Mikuni 30mm, so, I put the 115/30 jets in, moved the clip on the needle to the middle slot, opened the PMS exactly 2 turns. WOW! I took it for a quick test ride and got to 61mph on the GPS and the bike had more to give.
Old 04-22-2016, 11:53 PM   #26
lmg1974   lmg1974 is offline
proper carb and jetting does a lot for a bike!!!
Old 04-23-2016, 08:52 PM   #27
2015, rps
Old 04-24-2016, 12:27 AM   #28
So far I have heard of three, 2015 Hawk bikes with the bad air box/hose connection.
Wolftrax
Farmbath
Blackhawkdown
Old 04-25-2016, 07:35 PM   #29
slimjim503   slimjim503 is offline
Hi everyone it's been along time just order a hawk 250 what carb are you guys putting on could you send me a link
Old 04-26-2016, 01:16 PM   #30
Here is what I installed:
http://www.ebay.com/itm/360100626734
I also bought and installed these jets from: http://jetsrus.com/
GENUINE Mikuni pilot jet size 30 ( VM28/486)
GENUINE Mikuni main jet size 115 ( N100.604)
Turn the PMS exactly 2 turns out, voila! (I'm at sea level)
