Old 05-27-2016, 11:29 PM   #16
dpl096   dpl096 is offline
dpl096's Avatar
Excellent work tracking down the issue! Put some locktite on that screw so you won't worry about it backing out in the less than tight condition you will be using. These China bikes have a charm of their own with there little issues. You just have to manage their cheap fasteners and parts etc. Chinese proverb say, One must become one with machine, one must become ,the bike whisperer.
lol
― Thomas Jefferson
Old 06-02-2016, 08:34 PM   #17
Sport Rider's Avatar
John.....
extra gold star for you today! my brake light was not working off the hand lever. I removed the switch this evening. it may have been the wire connection...not sure....but either way, it's working now that I reinstalled it!
just goes to show, the things we post here, even minor issues we find, help everyone!!!
Old 06-03-2016, 03:36 AM   #18
Johnp   Johnp is offline
Johnp's Avatar
Yeah!!! Glad to finally be able to return a little bit of the assistance I've received here. :-)
John P.
2016 Hawk 250 - Black
All my mods are documented on my Blog!
My Blog | Google+ | Twitter | Facebook
Old 05-27-2017, 07:38 PM   #19
clark   clark is offline
clark's Avatar
Wink Magician 250 front brake switch adjustment (er, not) Switch appears same as on a Hawk
Credit to JohnP for this "By design, it looks like when the brake lever is inactive it should push the little button in, and when the lever is squeezed it should let the little button pop out."
On my newly arrived Magician 250, I noticed the brake light was "always on" even when the brakes were not being used. So,
1) disconnecting the front brake switch, and the brake light went off, and the rear brake when pressed, properly activated the brake light.
2) reconnecting the front brake switch, I noted that when I manually depressed the brake switch "post", the brake light went off.
3) So, there was an adjustment needed between the front brake switch post and the front brake lever were the lever depresses the post.
4) However... there is no adjustment mechanism (correct me if I'm wrong.) Just an alignment pin and attaching screw.
5) So, I needed to add about 1/16" "filler" to the lever to sufficiently depress the switch post.
This I did by using a small piece of thick double-sided tape, and a matching piece of sheet aluminum from a soda can. And voila! Enough filler to now depress the switch post sufficiently when front brake lever is not in use.
See pictures. The edge view of the double-sided tape is white in color.
Magician 250 (9/2016 engine label)
Kawasaki 650 KLR
Honda 1300 VTX
Qlink XF200
Old 05-28-2017, 12:33 AM   #20
Good deal. Sometimes ya gotta do what ya gotta do to get er dun.
Old 05-29-2017, 06:47 PM   #21
SLaYMoE   SLaYMoE is offline
SLaYMoE's Avatar
I had the same problem , Googled it before I posted and found John's post, Problem solved!!!! Thanks John.
