08-28-2016, 09:57 AM | #16 |
As an FYI, if the rotor is standard issue China 6 bolt pattern, a ninja 250 rotor will bolt right up. The ninja 250 rotors are a touch thickernel than the China issue, and can be had pretty cheap for a take off part on ebay.... on my rocket a db07a, the rotors are the same pattern and diameter as my 85-86 ninja/ex250 rotor on my supermotorcycle wheels aside from the ninja being thicker in the braking area, which should help the warping...
08-28-2016, 12:57 PM | #17 | |
https://www.amazon.com/EBC-Brakes-MD.../dp/B00666JOUO and check out the pads to go along with it for total $110.
08-29-2016, 07:39 AM | #18 |
it doesn't look like that particular rotor will fit, but any rotor for an 86-07 ninja front should work..... assuming the bolt pattern is the same.... I xan take measurements today to verify if someone can measure thier rx3....
08-29-2016, 02:18 PM | #19 |
so dimensions of my ninja rotor.... 130mm ID for the center hole150mm center to center on the bolts across the farthest 2, and 260mm outside diameter. also has a 4.8mm thickness
08-29-2016, 02:33 PM | #20 | |
http://www.chinariders.net/showthread.php?t=15528
08-29-2016, 03:14 PM | #21 |
I know it will fit the roketa bikes with a 6 bolt rotor, I.e 99.9% of the bikes with USD forks... I was gonna swap my rotor onto the wheels, but like the look of the matchimg rotors front and rear on my ninja rimmed supermoto....LOL its the little things in life....
08-31-2016, 10:33 AM | #22 | |
Peter Y. |
09-01-2016, 03:47 PM | #23 |
dang that sucks......
09-01-2016, 06:31 PM | #24 |
Bummer, Peter. Is there enough material to elongate the mounting holes to make it fit?
09-01-2016, 09:04 PM | #25 | |
The Zong is not listed on any EBC info that I have found. That's a shame because the EBC disc is a quality bit of work...much nicer than OEM. Now I want to see if it will fit on my V7. Peter Y. |
09-03-2016, 12:55 AM | #26 |
CSC has an oversize rotor kit with 11.5" rotor, sintered pads, bracket and bolts.
http://www.cscmotorcycles.com/RX3-Ov...p/csc-3100.htm
Dan CSC RX3 Cyclone, CSC TT250, Moto Guzzi V7 II, KLR650 |
09-03-2016, 07:10 AM | #27 | |
09-13-2016, 07:58 AM | #28 | |
yeah, it just isn't worth the investment. I am just going to buy a new stock rotor. hopefully by the time I go on another big trip, luke will have gained more confidence as a new rider. Technically speaking, he did the whole ride on a learners permit. |
09-13-2016, 09:53 AM | #29 | |
http://www.chinariders.net/showthrea...=16308&page=22
09-13-2016, 01:18 PM | #30 | |
I'm trying to do the same thing now with no success. Tried a heat gun on max setting for 5 minutes, then used my battery impact driver. No luck budging any of the bolts. I'm thinking of using a torch.... I ordered a new stock rotor and bolts from CSC, thinking I would never get the old one off. jb
2016 Honda CB500F......2017 Triumph Street Twin 2014 XT 250........ |
