07-26-2016, 01:22 PM | #16 |
I'd like to retrofit a snail shell adjuster to it. need to look at some parts to see what I can make work or if I need to mill something custom.
07-26-2016, 01:35 PM | #17 | |
07-26-2016, 04:19 PM | #18 | |
07-26-2016, 04:34 PM | #19 |
Ed McMahon says, you are correct sir.
07-26-2016, 04:43 PM | #20 | |
not pictured is already another tack on the other side. I was thinking the same to tighten it up with the correct length spacer. Or even just tack weld on an additional washer to it if narrow enough You know how these things go once the ideas start flowing. Kohburn sounds interesting too.
07-26-2016, 05:01 PM | #21 | |
07-26-2016, 06:59 PM | #22 | |
07-26-2016, 09:36 PM | #23 |
I think on one of the braZil 23o DP bikes I saw an aluminum instead of stamped steel, swingarm of a MUCH better design, I wonder if such a thing is available somewhere on one of the chinese online shops, that would fit our frames....
07-27-2016, 12:47 AM | #24 |
The owner's manual for the RPS Hawk (http://therps.net/User%20Manual/Hawk...s%20Manual.pdf) lists 60 foot pounds for the rear axle. With an average amount of testosterone there's no need for a cheater bar to attain that. I don't recommend an open-end wrench, either. I use a hex spanner from another m/c tool set.
Regarding the "spacer slop" first reported by Seer Atlas' brother: attached is the photo of my rear axle with the nut removed. The axle is a tight fit in the slider with no slop. I re-installed the nut using my 1/2" drive torque wrench. 60 ft. lb. doesn't deform the swingarm a bit. IMO, with the correct slider/spacer installed, there's no need for an over-engineered fix. That said, the initial problem may have been either a Friday bike or part of a bad batch of parts. If anyone on this forum is old enough to have worked on AMC cars, they sourced parts from different OEM's depending on the year, model, and lowest bidder. Haosen is probably doing the same thing - building bikes with whatever they had on hand. Remember, Haosen is trying to meet the demand for quantity, not for quality. In the case of my bike there are many parts that don't line up as they should. Like the exhaust valve tappet bolt. Only one edge of the bolt actually contacts the valve (they should mate squarely). As a result I need to adjust that valve tappet every 300 miles or so (the edge of the adjuster bolt gets rounded off and will continue to do so until I've adjusted an 360 degree turn of the bolt). I've not yet learned to enjoy it, but I'm getting really good at pulling off the gas tank \-:
The short list: 2011 Suzuki Boulevard C50T 2021 Chongqing Liyang Jiayu Hawk 250 DLX EFI 2017 TaoTao CY50-B scooter 79cc big bore kit - 45 MPH! (sold) 2015 Haosen Hawk (sold) 2002 Honda XR100R - project bike almost done. 2013 V-Strom 650 Adventure (sold )-: If I listed every bike that I've ever owned you'd either 1) Get bored 2) Be somewhat envious, or 3) Wonder: "What's wrong with that guy?" |
07-27-2016, 03:07 AM | #25 |
None of us are old enough to know the Matador, Pacer, or AMX. The AMX was pretty good and I never understood why they needed the Javelin.
07-27-2016, 06:26 AM | #26 |
my folks had an AMX before I was born. my little 5'2" mom would drive it into downtown Baltimore to work at johns Hopkins hospital. her clutch leg was strong.
07-27-2016, 08:54 AM | #27 | |
couldn't stomach the pacer, the mat was too heavy-too slow, but the javelin was a fun street racer once that small block was breathed on, and the suspension tightened up wasn't the fastest, but not bad bang for buck fun
07-31-2016, 03:37 PM | #28 |
I always wanted a Rebel.
07-31-2016, 03:38 PM | #29 |
To me, the answer is a different swingarm. Perhaps an early XR200R would be a good donor.
07-31-2016, 09:32 PM | #30 | |
When did Detroit really recover from the Japanese /import onslaught ? One might argue not until late 80's with Chrysler minivans, and Ford/Chevy suv's. Jmo.
