Old 08-22-2016, 12:46 PM   #16
The cool thing is you could fabricate a few different designs and then try them to quantify the difference.
Old 08-22-2016, 03:05 PM   #17
weld...rereading luna last comment and i thought of the dashed cut on the 4 edge too. i saw where you mentioned it. i am always trying to do something with least amount of work.(usually in too big a hurry and get punished and have to take the whole thing apart anyway )
Old 08-23-2016, 11:29 AM   #18
As Spud is fond of saying, there's never enough time to do it right but there's always time to do it twice.
Old 08-23-2016, 03:30 PM   #19
LunaTech   LunaTech is offline
LunaTech's Avatar
I am going to close the end off so the air flow goes through the drilled holes and add the wire mesh to make it legal for National Forests. I may redo the entire thing because I just went to Harbor Freight and purchased an 8 inch 5 speed drill press for $54 so now I can actually drill the holes straight and evenly spaced. Thanks for all the kind words and suggestions.
BTW I can tell a big difference in the speed and HP of the Hawk. K&N filter should be here tomorrow evening and I'm going to rejet when I put it in. I have a little bit of popping on deceleration now so I suspect it's a little lean after the exhaust job. I've already went to a 110 main so I'll try a 115 or 120. Pretty fun to be tinkering with a bike again. I had my old ZRX dialed in and all I ever did to it was ride.
Old 08-23-2016, 03:34 PM   #20
Azhule   Azhule is offline
Might need to mess with the Adjustment Screws or go up a Pilot Jet size to cut down on the "Deceleration Popping", but a properly tuned engine with an "open exhaust" might make some 'decel popping' no matter how rich the carb is tuned
Old 08-23-2016, 04:25 PM   #21
LunaTech's Avatar
Yea, I'm gonna take a gander at the plug and see if it tells me anything before I rejet.
Old 08-23-2016, 04:30 PM   #22
You won't regret that bench top drill, you will find continuous uses with it. I bought a craftsman a few years ago and paid too much but have loved having it. It really is a cornerstone shop tool.
Old 08-23-2016, 05:06 PM   #23
LunaTech's Avatar
Funny thing is I was in industrial maintenance for over 20 years until 5 years ago when I changed careers (sort of anyway). I worked in a machine shop and had access to every piece of equipment you could want. Since then I've been trying to put my home shop together. One piece at a time....
Old 08-23-2016, 08:10 PM   #24
I'm sure there were a few missing pieces that were permanently borrowed
Old 08-23-2016, 11:17 PM   #25
LT, I recommend that you try a 112.5 before a 115.
