#16 |
The clutch slipping issues most likely stem from the additives in the oil, regardless of dino or synthetic. Make sure that whatever oil you're using dosen't say anything about improving gas mileage, if it does it most likely has Teflon (or something similar) added to it. Teflon will embed in the friction material of the clutch and cause it to slip.
#17 |
The clutch springs are the culpret. It's well documented that when the cluitch starts to slip, new springs fixes it. Also, it's moly in some energy conserving oils, not teflon, and oils today have such small amounts of moly, it's a non issue.
#18 | |
You're right, it is moly, but then you are wrong; it can cause problems for the clutch. Been there, done that. Read around on other boards, I'm not the only one. Usually clears up with the correct oil. TheBrainII said his slipping cleared up when he went back to Rotella.... hmmmm.... Some oils have a higher amount of friction modifiers than do other oils, they are not all the same. Never said it wan't the springs, could be, but oil is cheaper and easier to replace so it makes sense to try that first. |
#19 |
I don't want to jump into the middle of a pissing match here, I just want to add my experience & you guys can use it however you want. With regular 10W-40 motorcycle oil for break-in, followed by Amsoil 10W-40 full synthetic I experienced clutch slippage, usually when shifting into 4th and 5th gear, as well as over washboard bumps on dirt & gravel roads. After changing the springs I have no slipping when shifting into 4th & 5th, but I do get the slipping over the washboard bumps. Maybe what I assume to be slipping from the washboard bumps is in reality the woefully crappy rear suspension not keeping the rear tire in contact with the road.
2005 RSX-200E 2004 Suzuki Eiger 1999 Arctic Cat 250 1977 Kawasaki KH400, aka Green Ripper |
#20 |
I have run the rotella since day one. No problems, but I am thinking that since temps are now in the 40s in the morning I need to switch to a lighter oil.
I haven't noticed any clutch slippage, but I think the washboards roads are the tire bouncing and not the clutch slipping.
#21 | ||
#22 | |
#23 | ||
#24 |
I'm locking this thread before things get ugly.
Frostbite "The beatings will continue until moral improves" |
