Old 02-06-2017, 12:44 PM   #16
Merlin   Merlin is offline
Unfortunately, for some odd reason, China Riders is acting very weird on my daytime PC and I'm not able to search since later last week. Anyone else experiencing issues????
Ya most of us. Clear The cache in your browser. It worked for me.
Bashan Blaze
Old 02-09-2017, 01:22 PM   #17
mtiberio   mtiberio is offline
mtiberio's Avatar
any thought if this carb will fit a TT250? It has the flange, and a non-butterfly choke...
https://www.amazon.com/dp/B00BXLOQSM
Old 02-10-2017, 09:56 AM   #18
Ariel Red Hunter's Avatar
That's quite a deal. That particular model normally costs $89.00, so this is a bargain. Jump on it.
Old 02-10-2017, 02:46 PM   #19
mtiberio's Avatar
I did. Couldn't wait for confirmation, so I bought it on spec. Will be here tomorrow.
Old 02-11-2017, 05:53 PM   #20
mtiberio's Avatar
Don't buy the carb I listed earlier. Too small. I'm giving it to a buddy.
Old 02-11-2017, 10:43 PM   #21
chuck   chuck is offline
great
Old 02-12-2017, 10:29 AM   #22
The VM-26 is too small? For a 229 cc engine? That's more or less an 1 1/16th inch choke. That is plenty of carb for a Hawk or any other bike using that engine. ARH
Old 02-12-2017, 03:08 PM   #23
mtiberio's Avatar
Not saying the choke plate 26's are too small. All I know is the carb I got was too small
Old 02-12-2017, 04:35 PM   #24
physical size?
Old 02-12-2017, 07:16 PM   #25
Originally Posted by chuck View Post
physical size?
Yes it's about 5mm smaller then the VM26.
Bashan Blaze
Old 02-13-2017, 01:51 AM   #26
If that is true, it is not a VM-26. ALL VM-26's have the same venturi diameter (26mm). Just because the guy selling them says it's a 26 doesn't mean it really is a 26. On the flange, there should be numbers cast or stamped on there. Can you tell us what numbers and letters are on there?
Old 02-13-2017, 06:33 AM   #27
mtiberio's Avatar
I'm at work now, I'll get some pix tonight. Document the thing so at least someone else can avoid buying the wrong carb. And yes I'd say the carb was about 5mm smaller than the stocker (holding it along side and looking.) The venturi (at the slide) was oval in a vertical sense (taller than it was wide).
Old 02-14-2017, 06:46 AM   #28
mtiberio's Avatar
physical size?
Looks like a 22.
Old 02-14-2017, 10:40 AM   #29
Looks like a 22.
Well, you're right. It is a VM-22. Tell the guy who sold it to you you want your money back, and he pays the shipping back, too. I forgot where you got this. Was it e-bay? They'll force this seller to give you your money back. ARH
Old 02-14-2017, 11:44 AM   #30
Sullybiker's Avatar
Buying this stuff is tricky, isn't it? Hard to be sure.
I bought what I thought was a main jet kit from Ebay for a vm26, but they're not quite right. They're very similar dimensions, but the thread pitch is every so slightly larger, and they don't screw in. At least they were cheap.
I've ordered a couple from Jets'r'us so we shall see,
Can I get away without taking the tank off (as per CSC manual) to remove the carb? Looks like it is tight at the top but seems to be otherwise pretty accessible. I'd prefer not to have to pull the tank every time I'm messing about with jetting.
carburetor, mikuni, tt250, vm26
