Old 04-04-2017, 05:56 PM   #16
my01   my01 is offline
my01's Avatar
main difference to the JTF 328 is the distance from the 2 holes (Honda -JTF 266-=34mm),
wheras your choosen sprocket has 35 mm.
I hope yours will fit.
Confirmation would be great.
It´s never too late not to...
Old 04-06-2017, 02:56 AM   #17
Maripas   Maripas is offline
sprocket 13 teeth
yes, it fits perfect.
Also this one:
https://cea.de/Kettenritzel/Kettenri...o11rbg38sf9t80
Old 04-06-2017, 07:13 PM   #18
my01's Avatar
well..but I´m looking for one with 14t to increase the ratio
Old 04-06-2017, 08:21 PM   #19
my01's Avatar
Is it possilbe the you measure the inner diameter of your "original" sprocket?
17mmm, 17.5mm or 18mm??
and the thickness over all, which may be 7 or 8mm....?
Old 04-07-2017, 03:00 AM   #20
the inner Diameter of the original (as delivered, 12 teeth) sprocket is 17.0 mm.
The thickness is "not important" as far as the Profile (lateral cut) is dissymetric. you have to Mount the sprocket that the Offset with the smaller Diameter is looking to the Motor.
the effect of changing the front sprocket from 12 teeth to 13 theeth is, that the behaviour concerning Maximum motor turns, end Speed and torque changes a lot.
12 teeth: max. Motor turns up to 7000 rpm, end Speed 105 km/h, torque very good
13 teeth: max. Motor turns between 6000 rpm and 6500rpm, end Speed between 100 km/h and 105 km/h, torque moderate
I fear that with changing to 14 teeth you will arrive a Point where the effects will be negative. the Motor has not enough power.
I am just thinking about changing the rear sprocket with one tooth more. the effect stepts by changing the rear sprocket are smaller. but I have not yet the real specification of this sprocket.
front sprocket rear sprocket ratio
12 35 0,34
12 34 0,35 original
12 33 0,36
13 35 0,37
13 34 0,38 new
Old 04-07-2017, 07:41 AM   #21
my01's Avatar
you can just look at http://www.gearingcommander.com/
There you can choose Skyteam model:ST-V-Raptor
Old 04-07-2017, 08:06 AM   #22
my01's Avatar
for the back sprocket:
JTR 1826
http://www.jtsprockets.com/catalogue/model/1574
or
http://www.ebay.de/itm/Kettenrad-Suz...8AAOSwFqJWmjM-
serie: 34t
Old 04-07-2017, 09:44 AM   #23
my01's Avatar
Now .. I measured by myself:
front sprocket:
it is out of stock (serial Version): 13t (as mentioned in the manual)
inner diameter 17,0 mm (i agree with yours)
next diameter 20 mm (i agree with yours)
distance hole to hole 34 mm (I agree with yours)
thickness over all : 7 mm (I agree that doesn´t matter if 7 or 8mm)
slot : 4mm (I agree with yours)
So .. i´m astonished that you have one with 12t mounted original???
please check once more.
Old 05-07-2017, 03:34 PM   #24
my01's Avatar
12 35 0,34
12 34 0,35 original
12 33 0,36
13 35 0,37
13 34 0,38 new
okay...but I´m sure...the sprocket out of stock has 13 teeth.
You may check it at your bike,pls?!
so.. in effect :
stock: front 13 rear 34----ratio 0,38
changed front 14 rear 34----ratio 0,41
difference at 100 km/h= 7,14% 0r 490 rpm
Old 06-06-2017, 07:47 PM   #25
my01's Avatar
V-raptor frontsprocket 13T->14T
Today I canged the frontsprocket from 13 T to one with 14 teeth.
What I gained is a overall lower level of rpm. And you can reach higher speed in the lower gears.
What I lost is highspeed. On a short, very short test drive I only get 100 km/h speed. on the same road I reached 105-110 km/h before change.
I guess now the ratio is too long and the engine doesn´t reach his power peak.
okay... I will see, if I let it in this way or if I change back.
BTW: Mounted was a JTF329 13T (serial concerning to the manual)
Last edited by my01; 10-01-2017 at 08:42 PM. Reason: JTR is for back sprockets, JTF for the front sprocket
Old 06-07-2017, 02:54 PM   #26
Heedehcheenuh   Heedehcheenuh is offline
Heedehcheenuh's Avatar
Welcome aboard. Have fun with the new ride. I just got into scooters/bikes and enjoy it so far.
Heedehcheenuh
Chuck D
Ride on.....
2 wheels down and head on a swivel
