01-17-2019, 09:28 AM | #16 |
thank you all so much for the help and nzbrakelathes as soon as I have more funds I will be buying your toolset. Q9 is replacing the rocker cover gasket under warranty if the service department ever gets back to me. After emailing back and forth I was asked to call the service tech spoke with him he confirmed parts that are needed emailed service dept again informing them that I spoke with the tech and have not heard anything from them now. Hopefully, they get back to me soon would like to get back up and running sooner than later.
01-17-2019, 11:42 AM | #17 |
I like to use a breaker bar (or if you prefer, flex handle) to turn the motor over, since it's difficult with a ratchet. Like Jeffrey says, take the plug out.
01-17-2019, 12:55 PM | #18 |
really mine was very easy to turn with the ratchet with or without plug in feeling some compression then it goes loose right before I land on the T mark
01-17-2019, 01:36 PM | #19 |
ok, so I just checked. when the atv is in N when turning the flywheel counterclockwise I feel the piston moving in the upstroke as resistance starts but if I keep pressure and go slow I can feel and hear air escaping. is that normal? now you have me worried this motor was crap. I will record a video for you.
01-17-2019, 07:51 PM | #20 |
If anyone would be willing to try and turn your flywheel and tell me if it is easy with some resistance with the spark plug in using a ratchet
01-17-2019, 08:15 PM | #21 |
What size socket would one need to turn the fly wheel?
Hawk 250 Lithium Battery, Mikuni Carb 110 main jet, Bark Busters with Mirrors, Extended Mixture Screw, 428 O-ring Chain, 17-15/40 sprockets, Digital Cluster, Cycra YZ250F Skid Plate, Oil Cooler |
01-17-2019, 08:22 PM | #22 |
14mm or 9/16"
01-17-2019, 08:37 PM | #23 |
Cool, thank you! Now I got to go find one in my tool box.
01-17-2019, 08:41 PM | #24 | |
To put it into perspective on how quickly that piston moves, at a 1500rpm idle speed, that piston goes up and down 25 times a second. Comparatively, you are taking several seconds to do one compression stroke.
01-17-2019, 09:10 PM | #25 |
Ok thank you for the peace of mind. Megadan..
And to Alpha Reign thanks for the hands on help |
03-19-2019, 09:56 PM | #27 |
I am setting my valve lash tomorrow am I supposed to do this on a dead cold engine or a warm engine ? Also I am seeing 2 lines on the fly wheel a long line Followed by a shorter line about 1/3rd of a inch apart what one is tdc ?
03-20-2019, 02:23 AM | #28 |
the "t" and on the compression stroke.
03-20-2019, 07:59 AM | #29 |
I like easy... What and where can one obtain this tool? Is it Hawk specific? I have a TAO TBR7...
03-20-2019, 08:08 AM | #30 | |
