Old 02-18-2019, 07:23 PM   #16
schleppy   schleppy is offline
Just for others to know, I just pulled my carb and my 2018 TT250 has a 105 main jet, and a 38 "slow" jet according to the CSC diagram.
I also noticed that my idle jet was just a brass piece, no screw adjuster on it. And it's not a brass plug to drill out, it was just a brass bump you can thread out by hand. Looked at some other threads, I guess it's normal. I slotted it and set it to 1.5 turns out from bottomed.
Old 02-19-2019, 12:18 PM   #17
bogieboy's Avatar
Originally Posted by schleppy View Post
And you were getting audible knocking on 87?
hard to hear any knocking on a bike thats got an FMF powercore 2 on it....LOL
Old 02-21-2019, 01:13 AM   #18
elkhunter338   elkhunter338 is offline
My 2018 TT250 also has a strange rattle/knocking under acceleration. I have pulled nearly every panel off the bike to check for loose connections or connectors that could be banging against something. I zip tied everything tight, checked all the bolts, etc. Still making the noise. Maybe it's normal? It does sound a bit like knock...
Hoping CSC gets back to me today.
Mine has the same noise throttling up mainly 4k to 6k, idles smooth and no noise. Sounds kind of like spark knock but the engine pulls good from 4 to 6k, spark knock normally causes power loss. I am running 92, E0 gas.
Bike only has 28 miles, so I have not went above 6k. Runs good, no popping noise on deceleration, I am at 3,800 ft. Bike start quickly and idles perfect.
Old 02-21-2019, 02:44 AM   #19
pete   pete is offline
pete's Avatar
the TT250 has a AIS system....
that's where the popping on a closed throttle is coming from..
no amount of jetting changes will alter that.. Making the jetting
richer will make it pop/bang more... you are giving it more fuel to burn in
the exhaust pipe...
If you really want to stop it... remove the AIS and block the hole
in the head that leads to the exhaust port and the air box connection..
and/or remove the ignition source…..The cat...
When you shut the throttle fuel goes straight though the motor unburnt
and into the exhaust pipe..... so the AIS then lets air/Oxygen into the pipe
when the fuel gets to the red hot cat it burns "POP/BANG" you hear..
then a cleaner exhaust...
You can clearly see the AIS pipe going in to the head/exhaust port in the picture..
just remove it and make a blanking plate..
There are a few here that have done it....I have not got a TT250... so one of them
might talk you thought how and what parts to remove...
But it is very basic to do.... don't let anyone tell you other wise...
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 02-21-2019, 05:45 AM   #20
NzBrakelathes's Avatar
I have blanker plates, but easy way is cut a piece of exhaust gasket without the hole and put it under that hose/flange fitting so the LAW won't know you did anything.
File Type: jpg 706E3788-8801-4AF6-BA4E-8AF8B6F1E038.jpg (15.0 KB, 293 views)
Old 02-24-2019, 02:38 PM   #21
An update on my 2018 TT250. I went from a 105 main jet to a 100, moved the needle up one notch, and adjusted the idle mixture screw 1.5 turns out. I also put 93 octane in the tank. Around 250 miles on it.
The bike runs WAY better than factory, and pulls really nicely. The noise I have been hearing is still there, so I'm guessing it's not spark knock, given the recent fuel mods and octane increase. I'll pull the plug again at 500 miles and see how it looks.
Old 02-24-2019, 08:23 PM   #22
I’ve noticed Chinese engines to be a bit noisy kinda like a preignition sound but that’s main bearing noise and common
You got a 2 year warranty anyway? I wouldn’t worry it is made in China and not totally perfect and not totally bad
Old 02-24-2019, 08:25 PM   #23
Is the main bearing bad? Or are they just noisy?
Old 02-24-2019, 08:52 PM   #24
Just noisey
I had a 223cc with 25000km it was a bit houser later I had a brand new bike same motor it was noisey just slightly less
We sense too much on Chinese stuff and you gotta ignore minor noise etc
Old 02-24-2019, 11:12 PM   #25
Getting off topic, but does your Speedee indicate that it came from Excalibur Motorsports? They used to import the Shineray Speedee.
