#16 |
I’m liking that! When I did my Honda engine into a Suzuki frame I found I messed up on the front to rear sprocket alignment. Not the front to back, or side to side but the vertical. It messed with chain tensioning. When the rear suspension compressed, it put too much tension on the chain. And, on rebound, it made the chain super loose. It has something to do with centerline of both sprockets and the swingarm bolt. Just something to keep in mind as you proceed...
1988 Kawasaki KLR250 1969 Honda Z50 silver tag 2002 Ford F-350 7.3 diesel 1975 Corvette 2017 Chevy Bolt “Throttle twisting geek” -LFN |
#17 | |
#18 |
Yeah, I didn’t realize it on my mock-up so had big issues with chain too tight on compression and too loose on rebound. Finally put a home made spring loaded tensioner on it and seems to work fine. But, if I did it again I’d spend a lot more time messing with the perfect placement so the tension was tightest right at sprockets and swing arm centerline bolt being perfectly in line. Then it would be loose above and below the centerline. It’s complicated and I wasn’t paying attention. Got towed home the first trip out because of broken chain...
Heck, evidently my mad skills are good enough for a Chinese bike factory. ![]() Being towed by sister...
#19 | |
My method with an unknown bike is to support the bike on a stand under the motor with the rear wheel off the floor, and then remove the rear shock. With the chain tension backed off, I place a scissor jack under the rear wheel and raise it until the center of the countershaft sprocket, the swingarm pivot bolt and the center of the rear sprocket are in a straight line. At this point, the chain should have very little slack, without being guitar-string tight. I tighten the adjusters at that setting. I then lower the rear wheel, reinstall the shock and place the bike on the floor. I note the amount of slack in the chain at rest and document it. If the slack is excessive at this point, I need to consider a spring-loaded tensioner. If it is not excessive, I call it a win.
#20 | |
#21 |
Here a picture to show you guys why I need to lower the engine
![]() Do you see it??? ![]() ![]() ![]() ![]() ![]() When I mount the engine like this, the chain will slice through my shift lever axle as a chainsaw ![]() Take a look at the original XR frame, the front sprocket lines up with the swingarm axle. Guess Mr. Honda didn't put the chainroller there without a reason.... ![]() ![]() |
#22 | |
Nike's slogan is a fact; Just do it! Everyone can be some kind of mechanic, it's just a matter of (sorry, but again ![]() ![]() But ![]() |
#23 |
Fabrication as a whole is trial and error. Experienced fabricators are just guys that have made lots of the errors already lol.
#24 |
Not to belabor the point, but on both my XR600’s and my XR650L, the sprocket, swingarm pivot and rear sprocket centerline was with the suspensions compressed somewhat... I vaguely remember even using a ratcheting tiedown to compress it, then I’d adjust the chain. So, it was somewhat looser on compression and also on extension with the tightest spot in the middle somewhere.
#25 |
Any updates???
#26 |
I put an XL 350 in my Suzuki 230 Quadsport and it was difficult to say the least. The valve cover was almost touching the frame above and I had to use a heat gun to mold the gas tank to make room for the head. The biggest pain was the exhaust, had to fab a new header to clear the frame in 2 places and still meet the muffler. But at the time the fastest 4 stroke quad was the Honda 250X and I could easily outrun them.
#27 |
Here’s my nowhere as sweet attempt... I put an Honda XR100 into a TC90 frame...
#28 | |
************************************************** *** " Time you enjoy wasting, is not wasted." - John Lennon ![]() “I predict future happiness for Americans, if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.” ― Thomas Jefferson "If you don't know where you're going any road will take you there" ....George Harrison song |
#29 |
Nice way to play!
On the reverse of this project, I believe the older XR 200 motor should drop right in on those mount points. Member Fastdoc dropped a CB (OHC) Lifan motor right into his older XR200. Fit perfectly, as I recall.
#30 |
Doc did a nice job of that swap. In fact, there are only two years where a CB or CG will not fall into place on an XR200; 1984 and 1985. Those were the dark years with a dual OHC setup and they weren't as reliable.
