Originally Posted by Megadan
That is a really good indication that your idle mixture is too rich. If you have to go below 1 turn out from lightly seated on the idle mixture screw, then you will want to order a couple of new pilot jets. at least a 25 and maybe 27.5 and/or a 30 for really cold weather.
Did you remove the pilot jet it came with? Usually the markings are on the side of the jet and they are very tiny.
so after a quick ride after work, i pulled the carb off enough to turn the mix screw half a turn in(now it is one turn out from slightly seated). Fired her back up and went for a spin. seemed more responsive. This morning was about 25 degrees and she fired up no choke no problem. I'm definitely going in the right direction!
