Old 08-18-2021, 03:50 PM   #16
Your front forks may have gotten tweaked out of line. Find a way to support the front of the bike with the tire off the ground. Loosen up all the triple tree bolts then retighten. I know my bike never had any of these issue. You could basically let go of the handle bars and it was like riding on rails. Just lean and it would turn.
Old 08-18-2021, 05:29 PM   #17
MotorBike_mike84   MotorBike_mike84 is offline
Will do. Tell me does your X22R have “clink,clink,clink” sound in your rear wheel when riding. It sounds like it’s coming from the sprocket or chain. But I can duplicate the noise unless riding. It doesn’t do it in neutral either. I’m going to try and see if I can record the sound while riding but my bike is very loud. We’ll see what I get and I’ll post tomorrow.
Venom X22R
Fairing Bolts (gold)
Performance levers (Gold)
Handle Bad Ends (Gold)
Rim Trim (Gold)
Custom plate holder and rear indicators
LED headlights & running lights (6000k)
LED under carriage & Engine lights (RGB)
Aftermarket Exhaust carbon fiber (Aggressive)
Aftermarket Mirrors
Decals (Removed stock)
Old 08-18-2021, 05:50 PM   #18
Ok guys. Lifted the front. Everything seems right no play but I do have like an 8th of inch gap when spinning tire. (Tire isn’t round). Would that affect cornering and cause pulling from side to side. Honestly it feels like the tire isn’t bolted to bike.
Venom X22R
Rim Trim (Gold)
Aftermarket Mirrors
Old 08-18-2021, 06:31 PM   #19
Plump Kibbles   Plump Kibbles is offline
Originally Posted by Falkon45 View Post
Problem is, he has alloy wheels. Not wire spoked.
Whoops! Well.. I'll just sit back down
|2020 X-Pro Titan DLX| <-- FOR SALE!!
Old 08-19-2021, 07:30 AM   #20
I had sold the X22R a while back. The clink noise could be from a misaligned chain were the chain is grabbing the side of the sprocket tooth. Put it up on a swing arm stand and turn by hand to see if it is.
Old 08-19-2021, 07:51 AM   #21
Falkon45   Falkon45 is offline
Falkon45's Avatar
If your whell is out of round, or the run-out is off (not straight) that will definitely effect your ride. Also, check you brake caliper bolts and brakes. One might not be engaging all the way, and causing your pull.
Your tire could also be the problem. Look and see if it's deformed in any way. If the tire itself is bad, and could be the only issue. I think yours comes in a more common tire size than what my kpm came with, so reasonably priced tires could be easy to find, if that's the issue.
Old 08-19-2021, 08:40 AM   #22
Nope my front is 110/ 60-17. So far I can only finds 120/ 60-17. Don’t know if that will work or not yet. I have no idea about tire sizes and fitment.
Venom X22R
Rim Trim (Gold)
Aftermarket Mirrors
Old 08-19-2021, 08:56 AM   #23
The front tire on my tbr7 was out of round and I tried reseatting it with no real luck. I think it's just cheap tires.
2021 Tao Tbr7 - "Lucille"
2009 Q-link Legacy 250
Old 08-19-2021, 12:51 PM   #24
I agree. They’re the original tires from shipping so it could be the fact that they are just trash tires. Looking at a pair of Dunlop tires but I can only find 120/60-17. Bike has 110/60-17
Venom X22R
Rim Trim (Gold)
Aftermarket Mirrors
Old 08-19-2021, 01:13 PM   #25
You will be okay with the 120/60-17. Here's a good site for doing tire size comparisons. https://www.tacomaworld.com/tirecalc...0r17-120-60r17
Old 08-19-2021, 01:53 PM   #26
Falkon45's Avatar
I'd go with the 110/70/17. It makes your tire a bit taller, but you won't have to worry about the width of the tire. That's also a common size for small displacement bikes like the ninja 250/300/400, RC390, CBR250/300. Going wider on the front tends to affect the handling more than going taller. You'll lose a bit of agility. But, if you're not really getting "spirited" riding done and just cruising, then the 120/60/17 will be fine. I'd also bump up to 140/70/17 for the rear, also. You can go 150/60/17 in the rear. But, again, handling is effected.
