Old 12-17-2021, 03:41 PM   #16
shelbyzman   shelbyzman is offline
So the stator is bad, would my bike stay running? I have had to jump it because the battery isn't charging.....but can ride for hours with no problems and if it dies, I can kick start it with one kick after it has been warmed up. Although, the electric start won't work because the battery isn't staying charged up. Just trying to use the process of elimination. I'm pretty clueless when it comes to this stuff, I just know that when an alternator goes out on a car, it won't stay running.
Old 12-17-2021, 04:47 PM   #17
I'm thinking bad battery. Disconnect the battery and check voltage from battery cables while it's running.
Old 12-17-2021, 04:56 PM   #18
Amateur   Amateur is offline
Banned
Listen to whoever tells you to make it so it doesn't take MINUTES to start it. Batteries are not designed to do that and you are burning them up.
Hurt to read this crap. "I'm totally stressing my entire electrical system and I just can't figure out why I keep burning up electrical components". Good lord.
Old 12-21-2021, 08:44 PM   #19
I checked the battery and it is good...I'm going to change the regulator and see if that fixes the charging issues. Fingers crossed!
Old 12-24-2021, 08:03 PM   #20
I changed the regulator out (which was super simple and it fixed the charging issue.
Old 12-25-2021, 05:56 PM   #21
buzz   buzz is offline
good deal
