08-17-2022, 11:18 PM | #16 |
Charging battery
--Thumper-- ok man thanks I will charge the battery and reconnect it. Then put a voltmeter on the battery once I start it and rev it.
08-18-2022, 07:11 AM | #17 |
When I got my Storm, I had problems with the remote as well and eliminated it. After you've got your battery charged, let it sit for like half an hour and then check the voltage. If it's good, it should be around 13 volts. My battery was shot because it kept discharging completely because of a dead ground.
2018 Bashan Storm(sold) 2016 Magician 250 |
08-18-2022, 07:29 AM | #18 | |
If the charging test seems good, definitely check it resting, key off. If the thing is drawing power when parked, it will show a drop in voltage on the battery when you connect... Check voltage disconnected, then connect and see if there is a voltage drop. There may also be a little spark as you connect it if there is a ground fault or power drain somewhere. |
08-20-2022, 02:09 PM | #19 | |
So when I replaced the stator on the last engine. The bike made a really weird buzzing grinding noise. I felt like I put the stator on wrong so I opened the crank case and everything was still intact so I thought the engine was broken that's why I replaced the engine |
08-20-2022, 02:09 PM | #20 |
I thought the engine broke somewhere else so I just replaced the engine
