#16 |
Vertical (level), with the dipstick just set in the hole, not screwed in, as I found out.
#17 | |||
#18 |
Hello, here is a picture of the gearshift side of the motor. I circled the oil filter screen nut in red. Hope this helps
![]() Regards, Stew ![]() |
#19 |
Yep, when you remove that nut there is a spring and a metal screen filter. It is the only place to drain the oil though, were you looking for a different filter anthony ?.
#20 | |
#21 |
Nope, it's a metal screen cone shaped filter. How did you change your oil without removing that "decoration bolt"?, i didn't know there was another bolt on that engine you could drain the oil out of it.
#22 |
i used my drain plug under my motor
#23 | |
#24 |
#25 |
waynev, you and I obviously have the same run of Beast motor, as I do not have a drain plug on the bottom of my motor either.. however, W&G's does.
I have a flattened/machined area where the bolt 'should be' but no hole. ![]() It's kind of like they 'forgot' that part of the machining process on some of these motors. ----- Go Canada Go! ![]() |
#26 | |
#27 | |
waynev& turboT what is the manufacture date on your gio beast??? |
#28 |
The date on mine is April 2008.
#29 |
that is odd i also have April 2008
#30 |
To continue with the oddities, mine is April 2007 and so is TurboT's. To confirm what T said, mine has the drain hole and his does not.
To answer your question anthonyfa18, yes, my Beast has the filter; so will yours.
