#16 |
Hi guys,
Think you might be mis-interpreting my explanation. None of the connectors have come off the wires, YET. However, four wires go into a white plug, which slides into which I believe is the cdi, perhaps it is the stator? Anyhow, as the white plug with the four wires slips into the receptacle on the black box, all the wires push away from the connection point instead of staying in the right spot INSIDE the white plug. I don't think I can solder inside the white plastic connector. I did tighten it up again, and wrapped tape avoid it rattling and pulling out. It ran all day which is the first time for 4 days. |
#17 |
Just to clarify.. this is not the cdi plug but plug for the rectifier.
