View Poll Results: Which Zong tank plastic do you prefer?
Factory Tank Plastic 26 47.27%
3-Fin Tank Plastic Mod 2 3.64%
2-Fin Tank Plastic Mod 2 3.64%
No-Fin Tank Plastic Mod 5 9.09%
Clarke 4.1 Gallon Fuel Tank 20 36.36%
Voters: 55. You may not vote on this poll
Old 08-21-2009, 06:37 PM   #16
Originally Posted by DesertRider
8O what you doin spud ? From what has been shown, I like the original still the best.
Your vote is currently in the lead, DR.
I can always return to the original equipment by ordering new plastic. Since the plastic mounting tab broke off, I would still need to replace the original plastic in any event. Therefore, I decided I might as well experiment a little bit. After all, experimenting is just part of the fun in owning a Chinese motorcycle.
Old 08-21-2009, 07:10 PM   #17
Spud, I'm going to need an aftermarket tank option before I can vote.
Old 08-22-2009, 12:07 AM   #18
AZ200cc   AZ200cc is offline
Maybe a cut but not as much, Kinda squareoff the edges and make it match the sharp edges the rest of the bike has :? How do You like that fine art work?
Old 08-22-2009, 01:23 AM   #19
That's a good line. Anybody else have photoshop experience that can clean that up a little?
Old 08-22-2009, 01:45 AM   #20
That cut deep man My windows paint skills don't cut it do they?
Old 08-22-2009, 02:19 AM   #21
Your art work is very nice, AZ. However, your sections won't work, because the mounting tabs at the front of the tank plastic would be cut away, leaving the front of the tank shroud unsupported. :(
Old 08-22-2009, 02:23 AM   #22
Ummmm Your cuts are farther back...What's supporting it than? :wink:
Old 08-22-2009, 02:24 AM   #23
Can you fabricate a new pair of mounting tabs? It might take some creativity, but that's nothing new to you.
Old 08-22-2009, 02:35 AM   #24
I didn't mean any offence. It just looks like you held a paintbrush in your mouth.
Old 08-22-2009, 02:45 AM   #25
I'mma go cry now
Old 08-22-2009, 08:43 AM   #26
Jim   Jim is offline
I like factory still.
"Be excellent to each other"
Old 08-22-2009, 08:00 PM   #27
After my cuts the tank plastic is much smaller, weighs less, and has less wind resistance. My current tank plastic is supported by two bolts at the rear of the shroud, and the gas tank itself. Movement in the horizontal plane is further limited by the filler neck of the gas tank, which protrudes through the tank shroud. Movement in the vertical plane is limited by the saddle, and the rider's weight upon the saddle.
If one really wanted, he could make your proposed cuts, and he would probably not encounter any difficulties with shroud support. However, the view from the front of the motorcycle would not be esthetically pleasing without the fake "radiator" present to conceal the "elephant ears" of the flaring, unsupported plastic.
Old 08-22-2009, 08:53 PM   #28
phil   phil is offline
im with jim i even like the factory size tires if i could afford them (but im trying to get that changed)
halls auto
l
coolster, modcycles, yanmar & zongshen, dealer
fired roketa,lifan and jet moto and apollo quit me who's next
Old 08-23-2009, 12:00 AM   #29
Upon further reflection, I believe your proposed section lines would work, AZ!
As you can see below, the mounting tabs on the Zong’s tank shroud are probably located inside your proposed section lines.
Therefore, one could trim off the lower “ear lobes,” and square off the front of the Zong’s tank plastic. However, the front section line would extend slightly forward of your proposed line, to allow the metal “radiator” brackets to mount to the frame.
Personally, I would not modify the tank plastic if I were keeping the metal “radiator” brackets. However, you offer a very nice, valid option, if someone wishes to eliminate the “ear lobes” from the Zong’s tank shroud.
P.S. I love your artwork; it reminds me of the French Impressionist School.
Old 08-23-2009, 12:07 AM   #30
Thank you for the kind words, WG. However, it appears that it would not be necessary to fabricate new mounting tabs to accomodate AZ's proposed section lines.
