#16 | |
#17 | ||
![]() Spud ![]()
#18 | |||
#19 | ||
![]() ![]() Spud ![]()
#20 | |||
#21 |
Here's a link for sprockets that fit these lifanoid bikes . also theres a chart there , so you can compare what you have now . http://www.jtsprockets.com/52.0.html...el_uid=4735&p= i'd also like to know in relation to the speed limiter ,how many rpms your bike is revving now . My current gear combo is 17 front 49 rear 65mph about 7000 rpm .
#22 | |
#23 |
we would need you to count the teeth on your front and rear sprockets to know for sure what you currently have . does your bike have tach on it ? how fast does it go now ? and what are the rpms on the tach while at that speed in 5th gear ? my bike had 17 tooth front and 56 tooth rear spocket and was at 8000 rpms at 60 mph by the bikes speedometer
#24 | |
#25 | |
#26 |
You may not need to take the cover off to count the front . If u can see it , mark one tooth with white out raise the rear wheel off the ground and rotate the wheel while counting till you get back to the mark . hope this helps .
#27 | |
#28 |
Some one said that it was common on those to to have difficulty finding neutral, I have had two of those and both were flawless transmissions. I bought them used and sold them both.
#29 | |
#30 | |
