Old 04-24-2015, 06:01 PM   #3121
Originally Posted by woodlandsprite View Post
The clearance issue seems to be something that all bikes have to contend with to various extents.
I noticed the barkbusters on my husband's bike are a bit nicked up where they hit the aftermarket windshield brace - basically there is no extra room at all to get a full turn of the handlebars.
Guess I'll sit tight while you experiment and hope that when my bike gets here I'm less prone to dropping it. *sigh* all parts of learning it seems.
Are you acquiring new grips as well?
The windshield of the RX3 has large cutouts to accommodate the full-lock position of the handlebars, so I am optimistic.
The stock handgrips are very thick, which I prefer. I like them a lot. Therefore, I haven't decided if I am going to get new grips.
Old 04-24-2015, 06:15 PM   #3122
woodlandsprite's Avatar
Based on that, I'm guessing it means you can reuse the grips, or you have high confidence in being able to do so with the swapped out bars - was wondering if there is a "standard" for the taper on bar center to bar end so that components fit properly on aftermarket bars.
hopefully that made sense!
Old 04-24-2015, 06:24 PM   #3123
Yes, using an air compressor, it should be easy to remove the stock grips, and install them on new handlebars. All handlebars are standardized with 7/8-inch diameter at the ends. Therefore, all levers, switchgear, et cetera, can be transferred from any set of handlebars to another set of handlebars.
Big bar handlebars (1-1/8 inch) are thicker at the center, for added strength. However, they taper to the standardized, 7/8-inch diameter at the ends.
Old 04-24-2015, 06:38 PM   #3124
Just an FYI, was just talking to Ryan at CSC, he mentioned they were able to install a pair of Barkbusters wraparounds (I'm presuming he was talking the brand, not the generic styling of hand protectors) - but he indicated they had to customize the clamp hardware - the stock clamps were too long and were resulting in hitting the windshield *sigh*
Old 04-24-2015, 06:49 PM   #3125
Veteran   Veteran is offline
Veteran's Avatar
Zs177mm
Yes.
Yes.
Yes, every ZS177MM/NC250 engine has 2 intake valves, and 2 exhaust valves.
Thanks Spud.
Old 04-24-2015, 07:09 PM   #3126
pete   pete is offline
pete's Avatar
So with the limited miles you have put on the bike...
hows the vibration if any..... handle bars/foot pegs..
looks as if thats something i have to start concidering
now... As I now have carpal tunnel my XT660 gives my
right hand a real hard time..goes numbe in about
30mins of riding at 100kmph... 4000rpm is a real
bad vibration zone on the XT...
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 04-24-2015, 07:11 PM   #3127
oldqwerty   oldqwerty is offline
Some big cruisers and tourers have 1-inch handlebars under the controls. Pretty much everything else in the world is 7/8.
Are the stock bars aluminum or steel? If steel, with only a 1/2 inch hole, they would be very heavy. Tough as a tank, but way heavy. If there is that much material there I'll just tap some threads and drill the guards to match. Simple solution.
If anyone is installing grip heaters, wrap the left bar with friction tape to the approximate diameter of the throttle tube on the right. Then install the heater and a right side throttle diameter handgrip on the left. Otherwise your handlebars will suck heat so hast your left hand can be cold and your right hand sweating. I know, that means buying 2 sets of grips, but you can befriend a 4-wheeler person with a gift of the two smaller grips because 4-wheelers don't have throttle tubes.
"Thou shall not Zong" is not a commandment.
Old 04-24-2015, 07:21 PM   #3128
Originally Posted by Veteran View Post
Maybe someone who knows Zongshen motors can school me here;
The RX3's we're getting have the Fuel Injected ZS177MM water cooled, 4 valve engine;
- Are all ZS 177MM engines basically the same?
- Is the ZS177MM also called the NC250?
- Do all ZS177MM water cooled engine made for all other applications have 4 valves or are some 2 valve engines? (I know we aren't getting 2 valve engines in our new bikes, so don't reply saying anything to that effect)
Thanks
Evan
I know Spud answered 'yes' to your questions, and there are a few bikes that have had this engine for a few years now. Here in the US, SSR Motorsports have been using the same engine for a few years now in their 250cc motocross bike http://www.ssrmotorsports.com/store/...ke/sr250s.html
The company Asiawing is the OEM for SSR's bike which is also sold into other countries under various brands. http://asiawing.com/english/index.asp
One of those obscure (at least for us) European manufacturers uses the same engine, but apparently manufactures their own bike. Someone can remind me what the brand is...
The reason I mention this is that this engine has been sorted out for a little while now, so it is not 'untested'
Old 04-24-2015, 07:32 PM   #3129
fishman10's Avatar
new zong rx3
Let me just say after a day of the real maiden voyage, i like the bike alot ,having the the same issue finding nuetral, but not a huge deal,,,,,but man if it was a 450cc ,i would be totally s.mitten!!!If zongshen /csc comes out with a 450 , Im buying it. i will look forward to some performance upgrades to this platform,cause i just really like the fit and nimbleness,and handling!
2015 zongshen rx3,,(Sold),,,2016 bashan storm,,2005 Harley ultra classic.
Old 04-24-2015, 07:33 PM   #3130
fishman10's Avatar
handguards
i hope someone finds a set that works on the stock bars.
Old 04-24-2015, 07:39 PM   #3131
honestly, me too
Old 04-24-2015, 07:39 PM   #3132
AZRider   AZRider is offline
You do know you will have to road trip to Yuma one of these weeks before it gets too hot...
All I need is an invitation and I'll clear my hectic calendar
I'm heading to Springfield, MO for a Spyder get together for the next couple of weeks, but I'm free after that.
George
2016 CanAm Spyder F3-L
Old 04-24-2015, 07:43 PM   #3133
AZrider George mentioned fixing his issue on another forum by adjusting the clutch
http://cyclone-rx3.com/forum/viewtop...21e0bc7b560079
Old 04-24-2015, 07:44 PM   #3134
Were there any comments or questions from spectators?
Although I was parked between a couple of Adv bikes, I was lost in a sea of Harleys. I did notice several folks taking a very close look, but I like to look at other bikes when I'm at this get together, so didn't get the chance to speak to anybody.
George
Old 04-24-2015, 07:58 PM   #3135
There is a 300cc bore kit available for under $200. I'm tempted.
