Old 06-13-2015, 01:28 PM   #3691
For the new reader to this thread, it's important to point out that Miqueas is dealing with a South American dealer, and this in no way relects the service level at CSC in California. So far, everything I've read about CSC has been top shelf.
Thanks for mentioning that important point, Weld. CSC has provided superb customer service which is unparalleled for the sellers of Chinese motorcycles. Zongshen has elevated the status of Chinese motorcycles with the RX3, and CSC has elevated the status of customer support for Zongshen, and all Chinese motorcycles.
Old 06-13-2015, 06:52 PM   #3692
woodlandsprite's Avatar
So... i was taking the time to put some parts on the bike today and while I was glaring at the Center stand mount, I noticed some stuff accumulating on the bottom of what I presume is the engine case. I can't find where it's originating from
This is the left side of the bike, looking up at the bike from underneath. I can get a more zoomed out photo and mark where it is if needed. I noticed at least one drip on the outside of the engine case - but I wiped it before I thought to take a photo. There is definitely some residue on top of the bash plate underneath as well.
Whatever it is, it was semi congealed - and light brown in color at least that's what it looked like when wiped by a paper towel. Any ideas?
Old 06-13-2015, 07:20 PM   #3693
one more question - is the fuse compartment supposed to be secured to anything under the seat? It seems like mine is just floating around and needed to be safely tucked underneath when I put the seat back on.
The fuses are in the black box next to the red battery + terminal cover
Old 06-13-2015, 09:31 PM   #3694
fishman10's Avatar
Chain lube slung off by your chain ???,,, maybe
2015 zongshen rx3,,(Sold),,,2016 bashan storm,,2005 Harley ultra classic.
Old 06-13-2015, 10:22 PM   #3695
Hmm. I like that answer I'll clean the bike off tomorrow when I'm working on it and see if it comes back
Old 06-13-2015, 11:51 PM   #3696
AZRider   AZRider is offline
My Spyder cost almost $30K, OTD and I don't get the same level of service from them as RX-3 owners are getting from CSC. I'd say they are rivaling any major brand, American or Japanese.
George
2016 CanAm Spyder F3-L
Old 06-14-2015, 12:31 AM   #3697
This is the left side of the bike, looking up at the bike more zoomed out and mark where it is. I noticed at least one drip on the outside of the engine case - but I wiped it before I thought to take a photo. There is definitely some residue on top of the bash plate underneath as well.
I suspect you are seeing grease/lubricant being shed from the drive chain.
Old 06-14-2015, 12:34 AM   #3698
The fuse box is held by a metal mount containing two prongs. However, the prongs bend, and the fuse box tends to escape the mount.
Old 06-14-2015, 12:37 AM   #3699
huh. I saw the metal mount but for the life of me could not figure out how to get the fuse box to secure to it properly.
If anyone gets a chance and has their seat off, could you please nab a photo for me so I can see if I can get mine secured again? Otherwise I suppose I will see if I can get it secured with a zip tie. Or self fusing tape :P
Old 06-14-2015, 12:39 AM   #3700
Thanks for sharing your experience. I agree. I don't think anyone can claim better customer service from a local, brick-and-mortar dealer.
Old 06-14-2015, 12:45 AM   #3701
Bend the two prongs closer to the frame of the mount. Then insert the tab of the fuse box into the mount.
I have performed this procedure repeatedly, but the fuse box still escapes the mount. I need to experiment with methods to secure the fuse box into the mount. Perhaps a zip tie will work.
Old 06-14-2015, 11:48 AM   #3702
You can be quite creative with zip ties. I have an ignition coil with broken mounts on one of my bikes, so I wrapped two zip ties around the bracket on the frame, and they support two more zip ties that wrap around the coil.
Old 06-14-2015, 12:59 PM   #3703
I agree; I'm sure the creative use of zip ties will solve the problem.
Old 06-14-2015, 02:22 PM   #3704
JTHSPACE   JTHSPACE is offline
JTHSPACE's Avatar
I had exactly the same problem with my brand new V-Raptor - went for a 10 mile first ride and saw drops of oil, panicked when I saw it! By next morning, it had set hard(ish) and waxy. Definitely chain wax. Definitely not an oil leak. Cleaned it off, had a little bit more but not like the first "display".
Jeff
Riding bikes for over 40 years
Honda C50 / SS50 / CB125 / CB250
Velocettes (various)
Piaggio's / Honda's / Yamaha's
Raptor . . . . the List Goes On . . . .
Old 06-16-2015, 12:30 AM   #3705
rjmorel   rjmorel is offline
rjmorel's Avatar
my chain blew his nose also all over the counter shaft sprocket cover. rj
