#31 |
The adjustment at bars is controlling the movement of the slide in a more precise manner, there needs to be some free play in the throttle, Once that is set then u lightly turn idle screw on carb to stop the slide from going down. I originally was trying to set idle with the screw and was having all sorts of idling / running isues, Once I found out I was doing it wrong my issues went away
I guess the importance of having the free play at the throttle is what matters.
2018 BD125-8-x21rs ZS190/Genuine PE28 Kepspeed GP1 Exhaust Protaper se x110 bars/grips 1/4 MotionPro throttle Kepspeed Braced swingarm Chimera rear hub assy Grom Intergrated tail light Superlite Sprockets 17/32 custom made from Japan Chimera Swing Arm Bolt RK MXZ Chain #420 All Balls wheel bearings Motodynamic fender eliminator Coremoto ss brake lines Composimo 2.5 lower link Grom Calipers-w/ebc pads/rotors Michelin tire 140&120 13x4/13x7 fatties Grom forks |
#33 |
in good time
![]() I think I broke 40 miles maybe even getting close to 50 miles on the odometer today!! so maybe next week it will be broken in then I will go for plates by then for sure
"Hope for the best, Prepare for the worst, Be pleasantly surprised when the world doesn't fall down on you" "Life's too short not to enjoy it-So's my China Bike!"-Me ![]() |
#34 |
SO I filled my tank very full and I had the problem again tonight where it stalled, didnt want to start again. I left it alone for awhile still no dice...then I blew into and sucked smelly gasoline air out theu the rank vent and bingo fired right up!
so I think my bike is a bit cold blooded--MIGHT have had a pinched line before but pretty dogone sure I have a tank vent problem. After I manually got air into and out of the tank with my mouth (not sure which way Im supposed to be going with the air although I know the tank vent obviously vents the air outward) then I took it for a couple miles ride and stalled again--again wouldnt start and I "manually vented" the tank vent hose again and it fired up instantly again!! I think you were originally right with one of the first comments WHisky--the question is do i replace it? where do I get a new vent? or do I get rid of it..somehow? I mean I had checked the tank vent hose before when you said to but all I did was make sure it wasnt pinched, detached or ripped--now I think the vent itself or the placement or something with it is somehow faulty Also thanks for the reply on the adjustment--I noticed the tiniest turn on the carb screw like a 1/8th turn changes the idle speed A LOT--around one bar on the tachometer which is something like 333rpms--so I will definitley try adjusting the handlebars adjustment next chance.
#35 |
There's a 1 way valve on the vent hose it's under the tank towards. The handle bars, I took mine off and just have the hose.
#36 | |
Thanks again for the answer, i expect this to solve my problem unless I have a sticky internal carb problem instead or in addition to the suspected valve problem.---The reason i am Guessing IT COULD BE JUST THE CARB instead of the vent itself is because when I blow into the vent hose i think I can feel air coming out the carb drain --so it is somehow linked thru air pressure or i dont know--either that or I somehow have a carb ven lol ---I definitley want to map all my hoses for air/fuel and emissions when I take it apart to be sure of this issue and for anything like mods or other troubleshooting in the future~~!
#37 |
Hey all, new to the forum and posting because I have the exact same bike as the OP with the exact same engine and (drum roll) the exact same problem. Took it out on my first ride yesterday afternoon and ran great for a few miles during my first break-in run but stalled at a stop light and wouldn’t start for nothing. Ended up pushing it a mile home. After letting it cool down it started right up. I originally thought my aggressive break-in method broke it but after reading this thread I’m thinking it’s a gas issue also.
My solution before I continue any more break-in is to upgrade the carb and re-jet while at the same time removing all the CARB emission junk. The carb upgrade seems straight forward but is there a diy on removing the emissions junk? In all my searching I’m unable to locate anything. Thanks to all that has replied to sirmaxwell for help as you’re now helping me as well. ![]() |
#38 |
Some of the "pieces and parts" of the emissions stuff are laid out differently between the Gen1 and Gen2 models , but here is basically what you need to do ,and what you need to cap off.,and more or less where you need to look for it at. The air pump will be on the front(ish) of your engine ,with the inlet tube going into the head on the shifter side, opposite more or less where your exhaust bolts up.Take that pump off ,you will see one hose that goes to a connector on your intake - block that little pipe on your intake off with a carburetor vacuum cap.There will be a larger hose that connects to your airbox that comes from the engine , on the top side more or less right over your front sprocket, put a breather on that hose. When you take the airpump offf there will be a big black metal pipe that goes into the engine,if your bike had a bracket that attaches the air pump that can be used as a block off plate , do that. If it doesnt, you can leave that black metal inlet pipe on , and just cap it off with a carburetor vacuum cap.
The plastic can that is part of the emissions / air pump etc is at the rear of your gas tank , right under where the back two bolts holding the tank down are, under the seat. it has a black zip tie holding it in, cut the zip tie and get it out of there. The gas line elbow from the tank sits jammed against that plastic can and i have seen the gas line be crimped damn near shut there, so taking that plastic can out of there takes the crimp off it . Since you are in there now, it would be a good time to replace the very crappy stock fuel line with some good silicone fuel line . Ill try to post some pix here later to give you an idea of where all this stuff is but it really isn't hard to find . While you are in there doing all this you might want to take the stock air box out and replace it with a pod filter ,which will help performance even if using the stock carb.
#39 | |
#40 |
I recommend removing all that smog / emissions stuff if your state doesnt inspect motorcycles for it. That evap canister under the tank crimps the fuel line , for one and the rest is, it's a rat nest of potential vacuum leaks and stuff to get clogged up and cause issues.The highest reliability is gained by reducing the engine to it's barest, essential components then making those as bullet proof and reliable as possible. All that Emissions stuff does is add performance decreases and failure points too many to mention ,and it doesn't help it is made from cheap chinese materials which are prone to failure / reduced longevity, furthering the failure factor and potential for aggravation . I think i 'll go outside and beat mine with a ball bat , even tho its already off lol, DIE AIR INJECTOR CAN DIE !!! Hahahahahah!
#41 | |
#42 |
My Vader really 'broke in' around 500 miles if I remember right. I mean you can notice it running better. I could.
If you're up to it, I'd take all that emissions stuff off and do the minor upgrades to get it running well. I really like the cheap Molkt carb 26mm on Ebay. Anyways, seems like you're learning and reeling it in to running better as you do. Great read on your progress
BD125-15 |
#43 |
@cbrfxr67 I also like the Molkt carb, i wasn't really familiar with it but a friend of mine runs one and has had great results with it, I like the " push / pull" choke design ,and the Molkt I have to admit is easier to adjust the air fuel and idle mixtures as far as ease of access to the screws for doing so than the Mikuni .The Molkt uses Mikuni jets so those are cheap and plentiful and easily obtainable.
Anyone considering swapping out carbs should really give the Molkt a look, I already put a VM22 Mikuni on my Vader or I would go with a Molkt , i really like the easier to get to adjusting screws ,those can be a real pain on the Mikuni especially the air / fuel mix one.
#44 | |
#45 |
@Lardog Hey man, just glad you got it all done with no issues and it's running good !
I try to help people as much as I can, to pay back for all the help I got when I was new here myself ! And yeah, i agree the first gear with the stock sprockets is basically unusable, it's so low you cant hardly go 5 feet before you need to hit 2nd lol !
