08-17-2019, 05:59 PM | #31 |
thank you all again, but onto my next question. I have a quick list of what to do as I assembly the bike, if you would fill in the gaps if I miss anything for reflection later. Adjust valve lash, lock tight EVERYTHING, drain oil in it and replace with better oil, check spokes, replace Chinese tubes with heavy duty tubes, check chain/rear tire alignment, adjust carb (unsure if the bashan enforcer comes with a keihin carb or the Chinese knockoff), adjust throttle/clutch cable, like I said I may have missed something
08-19-2019, 12:54 AM | #33 |
Check to see you're bikes recommended amount, then adjust accordingly for your weight n such. More / less ml's. Spacers removed or added.
08-19-2019, 04:55 PM | #34 |
10-4 fork oil is on the list, as far as the motor oil that comes in it I have heard mixed comments on it. Is it worth keeping or should I change right away?
08-19-2019, 05:01 PM | #35 |
I don't know if you read the sticky at the top of the Dual Sport section. Lots of good information that will apply to your bike. Hawk 250 Information and Resource Guide. http://www.chinariders.net/showthread.php?t=20331
08-21-2019, 05:13 PM | #36 | |
08-21-2019, 05:22 PM | #37 | |
Tags |
hawk, tbr7 |
