#31 |
Got my registration, insurance, and permit. It only took 3 hrs at the DMV and there was no one there. Went for a long ride this afternoon loved it. Bike is still idling high, I think it may be an air leak.
#32 |
Great news! Have you tried turning the idle screw down?
#33 |
Yes I tried to mess with it a little. My dad and uncle looked at it tonight and they both think it's an air leak on the rubber piece comnecring the carb to the barrel I'm gonna order a new one for 12 bucks and go from there. I don't want to create more issues buy continuous changing of the screw.
#34 |
I have a question on tire pressure. I can't seem to google this answer. What should my tire pressure be about with street tires on the bike, is it different b/c they are not for dirt.
#35 |
What pressure are the tires rated for?
#36 |
28F/32R is a good general ballpark I use if no other data is available.
Happy to serve. |
#37 |
motorcycle tires i use on my bikes are between 32 or 36psi but i run my tires 5 psi under the the psi rating
#38 |
See that's what I thought the tires say 40psi on them. Does that sound high to anyone
#39 |
That's the maximum pressure which will likely be much higher than the correct running pressure.
Happy to serve. |
#40 |
Does anyone have a diagram of the pz30 carb. I have taken it off the bike again and have it apart on the workbench. I would like to know a little more about it.
#41 |
I don't have a diagram, but I have a PZ30 here. What would you like to know?
#42 |
Is the screw with the spring on it, on the otherside of the carb from the choke the idle screw? Featured in the first carb picture on page 1.
#43 |
Definitely. If you remove the slider, you'll see how it has a ramp at the bottom that the idle screw engages with. Basically, turning that screw in is the same as holding the throttle open a little.
#44 |
Got it. It idles and runs better. Still a little funky, it surges, it idles fine for a moment and then surges up and when I adjust the screw back down it idles too slow and dies. I cannot seem to find a perfect setting.
#45 |
Blame it on the PZ30. I've had waaay better luck with the 30mm Mikuni, and they're less than $40, including shipping.
