05-30-2017, 05:40 PM | #31 |
2.203 would be the correct size.
05-30-2017, 08:15 PM | #32 |
Hey JerryHawk250,
I'm glad you are on this forum and look forward to your posts. Have a great night!
Dan-O -2018 Tao Tao HellCat - DOA -2016 Hawk 250 - Kitty Hawk - eBay exhaust, Mikuni carb(120 main/30 Pilot), airbox mod with K&N filter, digital cluster, total LEDs, 17/45 sprockets, RK chain, Shinko 244 tires, trunk, aftermarket levers, burrito tube, skid plate, Sargent Cycle Seat... -2003 HD Sportster 100th Anniversary -1999 Buell X-1 Lightning - Race kit, Buell Seat |
06-01-2017, 12:16 PM | #33 |
Did you measure or replace your c-clip?
06-01-2017, 01:03 PM | #34 |
No, Your hub is 58mm or 2.283" , I think the 1.937" would be to small, that's why I said 2.203" I may wrong. Did you measure the original clip?
06-01-2017, 01:44 PM | #35 |
Clip Size
I don't have a clip to measure. Mine either broke or fell off. Either way, I don't have one. Are these c-clips like some head bolts, use once and replace?
06-02-2017, 11:22 AM | #36 |
Csc tt250
I was on CSC's website, very nice and user friendly by the way. Anyway, they have a tutorial on changing the rear sprocket on their TT 250. It has a C-clip, but you don't have to reuse it. Their sprocket is held on with 4 bolts and they tell you to use Loc Tight!
https://www.cscmotorcycles.com/Articles.asp?ID=318 After my experience, I'm all about customer service! Or in my case, lack there of! Have a great weekend!
06-02-2017, 11:30 AM | #37 | |
06-02-2017, 01:59 PM | #38 | |
g off of the shaft, they are not designed to take the pressure of mis-aligned sprockets...ARH |
06-02-2017, 02:03 PM | #39 |
06-02-2017, 03:14 PM | #40 |
06-02-2017, 03:23 PM | #41 |
When I changed to the 47 tooth flat sprocket (the stock TT250 sprocket is slightly dished), that's exactly why I opted and use the c-clip instead of the little spacers without the C-clip.
It's only about a 5+mm offset and with that long of a chain, I saw no harm/no foul, especially since the countershaft sprocket wiggles like crazy on the CG motor. Even if that minor of an offset wears out a chain 6 months sooner than normal, I felt much safer using the C-clip since Mrs. 2LZ is the one riding it.
06-03-2017, 09:27 AM | #42 |
I figure since this is relevant to the topic. While going over my new Hawk with a fine toothed comb I made a discovery with the rear sprocket. http://chinariders.net/showthread.php?t=19265
06-04-2017, 05:56 PM | #43 |
Megadan...I wish you would have gotten your Hawk before I got mine!
