#31 |
That's the gear postion switch.
#32 |
It is a shift indicator. Not all bikes China bikes have a digital gear display, but that is what operates it.
#33 |
Jerry's answer is better. I failed to realize that he had posted before I responded.
#34 |
![]() Now I take out that from the engine an now I can use the kickstarter without problems but I see little pieces in the engine and I want to take all apart but this flywheel... I cant take it out... Someone know how I take this thing out? And know someone where can buy this try wing or what that is to take the bottom screws apart? |
#35 |
Nobody can tell my why i can take that Flywheel out?
#36 |
I don't have a CG service manual with me in AZ but as I recall there are threads in the flywheel hub so you can screw in a bolt of the proper size so it will push against the crankshaft and push the flywheel off. It can take quite a bit of force if the woodruff key was sheared off when the engine stopped suddenly because of a piston failure.
#37 |
but need i to take the middle or the 3 screws of the flywheel for pop it out?
i have a flywheel tool but i need to screw it in and then i can just pop it out when i screw the other side in. I need to remove the middel screw for that and the other 3 or do something else? |
#38 |
Remove the middle bolt and leave the 3 outer screws in place. They hold the starter clutch to the flywheel.
#39 |
I try it but its too hard...
i hoppe i need to take it to te left to take it apart why all the others one. I lock the cylinder so that the flywheel didnt spin but nothing. to hard. maybe i need a impact gun for that : ( . |
#40 |
Yes, impact wrench may be necessary.
#41 |
an impact wrench would certainly make it much easier to remove.
