05-20-2012, 10:14 PM | #31 |
This is the mod I've done recently. The machinist didn't have band saw, i don't know what he used, but i think it was abrasive cut off saw. I painted the area where it was cut the inside with black colour so the gap is not that visible. My suggestion with this mod is (i'm just repeating but this thread covers most of it) 1.Look for machinist that has bandsaw. 2. Cover the inside with plastic bag or something like that because you'll have a lot of metal shavings and dust inside. Very hard to clean. I've poured some old oil inside and that colected a lot of that stuff. 3.Do a printout of Spuds pictures so machinist knows where to cut. 4. Try to do it on the same day. It only takes 5min. 5. You will need a new gasket. You can make your own. 6. If you are removing the stator. I was replacing my old. Not sure if you can do with stator inside. I couldn't remove those 2 bolts and thats how i took it to machinist. Later i would cut remove those 2 bolts. To remove them you will need (special tools )grinder, hammer and old screwdriver, or one of those metal cutters like the one i have in this picture. Preferably smaller one. I've reused those 2 bolts. Didn't want to waste more time ordering them from local shops. Try to take pictures or remember how you old stator was placed because few times i was puzzled. :oops: Overall very happy with the mod and I highly recommend it.
Zongshen 200gy-2 |
05-21-2012, 12:20 AM | #32 |
Thank you for posting concerning your success modifying the left crankcase cover, Pliskin. This modification is going to make maintaining your Zong much easier.
I see you successfully removed the stator, but were unable to remove the pickup coil. Zongshen applies a large amount of loctite to those bolts at the factory. :roll: I was able to remove all the bolts in my stator cover by employing the leverage from an allen key socket attached to a socket wrench. I recommend removing the stator and pickup coil from the stator cover before cutting it. I also recommend using oil resistant RTV to seal the grommet holding the stator wires in the crankcase cover, otherwise the grommet will leak oil. :roll: Zongshen uses an adhesive to secure the gasket to the crankcase, so one will probably damage the gasket when removing the left crankcase cover. :roll: Therefore, I recommend buying a new gasket before undertaking this modification. Spud
05-23-2012, 10:44 AM | #33 |
thanks for the additional info. also beware of the aussie professional. it looks like he botched it up with an angle grinder. did he charge you?
anyway, you ll probably find ways to make it less visible.
1971 Garelli Gulp 50cc with open ports and 16 mm Bing Carbie + 1980 Honda XL 223 ZS + 2007 Zongshen LZX200G + DR400SM |
05-23-2012, 11:54 AM | #34 |
Looks OK to me from the pictures, and it will function well. One way to clean it up would be a rubber channel of some sort from the auto parts store.
Happy to serve. |
05-23-2012, 02:09 PM | #35 | |
05-25-2012, 03:25 AM | #36 | |||
You are welcome Spud.
Plus you scared me when you said "RTV", was thinking, i don't know what i used. Till I went to check in my garage. Was i relieved when i saw those 3 letters on that tube. I only used it before for the section of gasket that goes over grommet. I thought it was only for the gasket. Can I also ask you did you use dielectric grease for electric connections from stator to other bits? I can see that they've used that before. So i am thinking maybe i should buy that too. Quote:
Thank you for that info about rubber channel.
Zongshen 200gy-2 |
05-25-2012, 01:35 PM | #37 | |
