#31 | |
![]() The XT225 cylinder has a longer stroke, as well as a bigger bore. ![]() ![]() ![]() However, the complete XT225 engine might bolt directly into the Zongshen frame with few, or no modifications required. ![]() Spud ![]()
#32 |
That makes sense. Not worth the extra cost of a crank and rod.
Lets see another 30K now. Allen |
#33 | |
![]() ![]() ![]() ![]() Spud ![]()
#34 |
It occurs to me youre Yamazong is leaning further and further to being a Yamaha more than a Zong!
Happy to serve. |
#35 | |
#36 | ||
#37 | |||
![]() Spud ![]()
#38 |
Top End Rebuild
Spudrider
Hello from Oz. Thank you for all your wonderful write-ups. With the top end rebuild, can I ask: *did you use a new Yamaha cam chain and sprockets or Zongshen? *Has your friend Andy expressed an opinion as to why the inlet valve recessed into the head? *Apart from the stutter at WFO, were there any other signs that led you to check inlet valve clearance every 500 miles? Regards Allan |
#39 |
I have to say I'm thoroughly impressed with the cleanliness of the engine internals. No doubt a symptom of your excellent maintenance
![]() The valve issue you were speaking of is how the pushrod Harley's I've had experience with have worn. Valves don't loosen....they tighten..... First sign, harder starting. When my old Ironhead chopper took more than 4 or 6 kicks....something was amiss. Odds are, the intake needed setting. As the valve pounds into the seat..along with the heat.....and the unleaded fuels came into play for lack of top end cooling and lube.....the valve seats would wear creating a sink hole. As the 'hardened' finish wore off....the more frequent you had to reset them.
#40 | ||
Re: Top End Rebuild
![]() ![]() Quote:
![]() My friend Andy has not expressed an opinion regarding the wear on the intake valve, other than the engine had delivered 31,656 miles of good service. ![]() ![]() ![]() After riding my Zong for almost 32,000 miles, I had become very familiar with its idiosyncrasies. ![]() ![]() ![]() As I became more familiar with my bike, I noted my Zong would become harder to start when the intake valve clearance had tightened. ![]() ![]() ![]() Because I checked the valve lash regularly, and became familiar with the idiosyncrasies of my engine, I was able to detect the accelerated wear on the intake valve, and correct the problem before my engine was damaged. ![]() Spud ![]()
#41 | ||
![]() ![]() Quote:
#42 |
Ok, haven't had much time to read the forums so I've been sticking to the ATV one for the last bit for the most part.. just had some time to read through this.
Good work Spud... I do have questions! ![]() I'm curious why you chose a .50mm piston and not the .25? You did mention it was the '2nd oversize' so I assumed a .25 would be available? You only have one picture of the actual cylinder after machining, and perhaps it's the picture quality but I didn't see much of a cross hatch pattern in the bore. I'm curious if you know how your machinist opened up the hole? Small barrels like that can be a bit tricky to machine that amount of material out of at once... especially two oversizes. Was this a specific motorcycle machine shop or other? My .02c on the head, good choice to use the other one. Just from eyeballing it looks like you'd may have needed a new valve seat and possibly a valve. The machining on the seat would've set you back a bit...and I would say installing valve seats in an aluminum head is a bit scary. 8O Overall looks like a bit of fun! ![]() -T |
#43 | |||
![]() ![]() Quote:
![]() ![]() Quote:
#44 |
Hey Spud I didn't mean to imply the machining was done incorrectly. I just didn't see a cross hatch in the photo (possibly just because it didn't focus on the bore) and was curious about it.
I have some experience with that type of thing, and my hands get sore just thinking of my time honing motorcyle barrels in our machine which was designed for connecting rods. (small diameter motorbike cylinders did not fit in the machine for honing car blocks) I think you're fortunate on the replacement head being available and in such good shape too. Not that yours wasn't fixable, but certainly a time and $$$ saver. I think you're good to go for another 30,000. ![]() |
#45 | ||
![]() ![]() ![]() ![]() Quote:
