#481 |
Tell me you’re a machinist without telling me you’re a machinist lol
2022 X-Pro Templar X 250 “Rocinante” 2022 X-Pro Bolt 125cc “Dapple” 2022 Royal Enfield Interceptor 650 “Traveller” 2023 Royal Enfield Classic 350 “Trigger” |
#482 |
Has anyone installed a nibbi pe30 carb or mikuni? If so how did you like it? 1,312ft above sea level, jetting recommendations?
#483 |
14 front and 42 rear sprockets with a rk chain done, really like the gearing. Am going to check the valves today and want to either rejet and adjust the stock carb (PZ30JB-ZM1) or replace with a nibbi. Any recommendations either way? 1312ft altitude. Any input on what jets and where to set needle on either stock or new carb?
![]() Last edited by AjjAxx84; 08-06-2022 at 03:16 PM. |
#484 |
What is cruising rpms like with the 14/42 combo? Top speed?
#485 |
[QUOTE=AjjAxx84;381997]14 front and 42 rear sprockets with a rk chain done, really like the gearing. Am going to check the valves today and want to either rejet and adjust the stock carb (PZ30JB-ZM1) or replace with a nibbi. Any recommendations either way? 1312ft altitude. Any input on what jets and where to set needle on either stock or new carb?
Is this the stock carburetor (in the picture)? |
#486 | |
[QUOTE=Thumper;381999]
#487 |
Going 35-40 bottom of 5th gear around 3k or so. 55-60 5k or so
#488 | |
My Templar X came with a smoothbore carburetor (https://www.chinariders.net/showpost...43&postcount=1), and modest jetting changes made it excellent start, idle, responsive, perfect spark plug read. can you post pictures of your OEM carb? |
#489 | |
My altitude is 1312ft, I ordered a jet kit from Amazon, what do you suggest? ![]() Last edited by AjjAxx84; 08-06-2022 at 05:38 PM. |
#490 |
I rejet the main from 120 > 125, and pilot from 40 > 45, and shimmed the needle with just one washer (about 1mm).
EDIT: 45 is a bit rich- no choke needed even in cold weather cold engine! Went 40>42 and Now a bit of choke is needed. Perfect. This is taken directly from the post that I linked...Pictures of the carb and this jetting information is in that post. But if you look at the carb, it is a YouALL smoothbore that I got. What jets came in yours? Is it a smoothbore? Last edited by Thumper; 01-23-2023 at 07:03 PM. |
#491 | |
#492 |
I set my valves to .002 and the exhaust seemed pretty hot as soon as the bike started, not sure if I’m just being paranoid but figured I’d ask
#494 | |
Mikuni 30mm won’t fit. Mikuni 28mm also will not fit stock intake boot-I had to make a spacer. The 28mm Mikuni is simply too large. A 26 May work but again issues with the intake side fitting the stock exhaust. It’s was a fun way to waste some time but honestly unless you’re playing with a flatslide or PWK it’s not worth it.
