Old 04-01-2017, 09:00 AM   #526
old kid   old kid is offline
old kid's Avatar
Originally Posted by goat67 View Post
What is the best way to set / check the chain tension for these bikes?
and to add to goat67's question, I have a pit posse chain breaker and punch but there isnt a pin or mandrel for a 428 chain in it, anyone know of a good kit for the smaller sizes, other than the cheep junk on ebay or amazon?
i've been looking around and can only find a link cutter.
Old 04-01-2017, 10:03 AM   #527
Kipper1012   Kipper1012 is offline
Kipper1012's Avatar
take three fingers and stack them vertically in between the chain and the swingarm just in front of the chain guide
2016 Green Bashan Brozz.
Old 04-01-2017, 10:43 AM   #528
RedHawk16   RedHawk16 is offline
Hi all.
Another newbie here. Wasn't sure where to post for being a new member (just signed up today). I have two Hawks coming middle of next week and hope I don't regret it. Have some of the mods coming also. I'm sure I may have questions along the way and this seems like the best place to find answers for the Hawks. First question would be is if anyone knows of a place the recommended RK428S0-130 chain is in stock and available. All I find is not available. Would a NK428S0-138 work if I just remove the needed amount of links? Found this on Amazon but somethings seems wrong about it actually being an o-ring chain for the price listed. https://www.amazon.com/dp/B00BT78NWU...I2SBUMQZYP9BB7
Old 04-01-2017, 10:47 AM   #529
Not sure if that link for that chain worked. Might have ran out of character space.
Old 04-01-2017, 12:26 PM   #530
goat67   goat67 is offline
goat67's Avatar
Chain Adjustment
Hello I found the manual for the Hawk here is the chain adjustment steps is this the right way to set the chain tension?
Old 04-01-2017, 12:32 PM   #531
goat67's Avatar
Mine from the factory is not even got a single finger of play. This is the reason I am asking.
Old 04-01-2017, 12:38 PM   #532
old kid's Avatar
the stock chain that came with the bike will stretch and loosen up fairly quickly
Old 04-01-2017, 12:46 PM   #533
I have the current manual also. I have read/seen video that the index marks are not right from side to side and to eye ball the center knob of the tire to the lower mono shock mount to center it.
Also noticed in that manual that it states that it has an o-ring chain. Is that true for 2016 Hawks? Some how I doubt it. Even if it is I'm sure it's still not good.
Old 04-01-2017, 12:52 PM   #534
old kid's Avatar
the chain that came on mine wasnt an o-ring, i changed it out at about 50 miles, i had to tighten it twice in that 50 miles. all i did to align it was to center the middle lugs on the tire with the shock mount. i also swapped out the adjuster nuts out with nylocs just to prevent them from loosening up, i didnt have any issues but others had them loosen up and were double nutting them
Old 04-01-2017, 01:28 PM   #535
Pretty much figure the factory stuff is junk which brings me back to my original question about the NK428S0-130 chain. Anywhere these are in stock or would this be the same if just removing the extra links? (RK Racing Chain 428SO-138 Steel 138-Links Heavy Duty Chain with Connecting Link) This is the title of it on Amazon and I wonder about the "heavy duty" part of it. In the description and picture it says and shows that it is an O-ring chain just like the 130 link one. But for $27.82 I really have a feeling it's just a heavy duty chain and not the O-ring. Like to get these mods lined up before I even assemble them so I can just do it while putting them together. Save the headache of taking them back apart again later.
Thanks for any helpful input.
Old 04-01-2017, 05:08 PM   #536
old kid's Avatar
i'm not familiar with the RK chains, we have a local shop here that sells D.I.D. chains, i bought the X-Ring 428/130, i have seen other posts where other people have bought the RK chains and had no issues with them. but you are right the chain that came with it was junk.
Old 04-01-2017, 05:20 PM   #537
this is correct. dont blame the chain if you dont adjust it! had to be seriously loose to jump off.
2016 hawk
kaw h1 400 tripple
13' long chopper in progress
2009 johnny pag bar hog
Old 04-01-2017, 06:14 PM   #538
Bruce's   Bruce's is offline
The longer chain is just fine ,nothing wrong with rk chains either .
Old 04-01-2017, 08:54 PM   #539
Ariel Red Hunter's Avatar
Yes, it is the same chain, just has extra links. If I ordered that chain, I'd get 2 or 3 extra master links, and a chain breaker.. Unless you want to grind the rivet head off with a Dremel or some other grinder...ARH
Old 04-01-2017, 09:45 PM   #540
Crying
Got a chain breaker. I'm good to go. Ordered that chain but it was the last one on Amazon. Need to find another one.
