07-07-2016, 11:58 AM | #46 | |
07-07-2016, 12:44 PM | #47 |
As far as SC vs nos goes, we've already discussed the heat issue of a SC as well as having to figure out a pulley to drive it. Also consider the space needed. If it's a suck through system it'll probably be hard starting and likely have response issues. If blow through you'll need a fuel pump and pressure box for the carb, or a carb that can take it without a box, or fuel injection. Also consider that it takes power to run the SC so for every 1HP you get out of it you will be putting more than 1 hp of strain and heat on the engine further limiting what you can get out of it. For perspective, the SC on a top fuel car takes about 500hp to spin and it nets about 1500hp propelling the car. These are old numbers and not directly scalable, but just a thought to ponder.
The only real downside for nos is that you do have to refill the bottle whereas a SC never runs out of free air. This motor would be getting a very small shot of nos so it wouldn't cost a lot to use for occasional bursts. On one car that I ran a lot I was shooting about 100hp and would make 4-6 1/4mile passes in a day with no problem on a 10lb bottle, refills were 3.50/lb. At roughly $4 per pass it would take a lot of racing to offset the cost of a SC. I was using it quite a bit so I made my own transfer station at home with 3 different bottles to get the most I could out of each refill. The bottle can't be used to empty so there's always some left. Running a little bottle on the bike and having a standard 10# bottle to fill it with will get you a lot of run time between buying refills. If you wanted a constant power increase like for high speed freeway cruising nos wouldn't be a good way to go, but heat would likely kill the engine under constant boost so I don't think it's a solution anyway. I had a Yamaha 650 turbo many years back and I remember feeling the engine heat on my legs when I'd run a long time under boost. In fairness I was sometimes shoving 16+psi into it, but even when I dialed it down to 12psi I could feel it and any amount of boost adds heat. |
07-07-2016, 02:13 PM | #48 |
Yes, motorcycles with no fuel pump typically use dry.
07-07-2016, 04:19 PM | #49 | |
Sincerely, John Doe "All forms of madness, bizarre habits, awkwardness in society, general clumsiness, are justified in the person who creates good art." -Roman Payne "Truth is stranger than fiction, but it is because Fiction is obliged to stick to possibilities; Truth isn't." -Mark Twain "I have never made but one prayer to God, a very short one: Oh Lord, make my enemies ridiculous. And God granted it." -(Letter to Étienne Noël Damilaville, May 16, 1767) |
07-07-2016, 04:23 PM | #50 | |
07-07-2016, 04:35 PM | #51 | |
07-07-2016, 05:28 PM | #52 | |
I thing ghosting is slang.... The heat from his engine was most likely the cause of his continued firing....
07-07-2016, 05:34 PM | #53 | |
for a decent accross the board gain just eliminate the cat. it's probly full of lead anyway. you need a welder to do it , cut out the section of pipe with the honeycomb in it and replace it with a meduim walled pipe of similiar diameter.. some porting of the weld imside the pipe at the flange area wouldnt hurt either. |
07-07-2016, 05:38 PM | #54 | |
07-07-2016, 09:20 PM | #55 |
https://www.monoprice.com/product?p_id=13860
www.raspberrypi.org/products/pi-zero/ Just a heads up. If you really want to use a single board computer to make an ECU, do use the Chinese knock off(that is ironic on this forum). They had really spotty quality. Go with the RaspberryPI Zero. It is just under the power of a RaspberryPi 2 but it only costs $5. Also if you are serious about the 3D printing look at the monoprice select V2. It is a rebranded Wanhao duplicator i3 V2 so it uses all of the same upgrades. An you can pick them up all day at $350. Even better, monoprice runs a 20% off discount every once in a while so you can get it for only $300 shipped to your house! Sorry the links are so funny. I am on a tablet so it is hard to copy and paste. I can fix it when i am able to get on a computer. |
07-07-2016, 09:25 PM | #56 |
http://www.reddit.comr3Dprintingcomm..._what_are_the/
Here is a link to so great upgrades for the Wanhao duplicator i3 V2/Monoprice select v2 |
07-07-2016, 09:31 PM | #57 |
Also, if you want a little boost in power why dont you put on the munki 30mm carb( not the 26mm that some people have put on) and the Pro Circuit T4 exhaust for the Honda CRF230f? It was already shown in a thread about an exhaust for the Hawk 250 in a video that the T4 exhaust nets about 5hp on a 200cc bashsan bike.
07-07-2016, 09:53 PM | #58 | |
Never heard of ghost running and no clue what belt you're talking about, there's no belt on that bike nor most other bikes. What fumes? You might be hitting the pipe a bit too much and the smoke has clouded your thoughts. |
07-08-2016, 01:33 AM | #59 | |
Sincerely, John Doe "All forms of madness, bizarre habits, awkwardness in society, general clumsiness, are justified in the person who creates good art." -Roman Payne "Truth is stranger than fiction, but it is because Fiction is obliged to stick to possibilities; Truth isn't." -Mark Twain "I have never made but one prayer to God, a very short one: Oh Lord, make my enemies ridiculous. And God granted it." -(Letter to Étienne Noël Damilaville, May 16, 1767) Last edited by Weldangrind; 07-08-2016 at 11:05 AM. Reason: Whare is the tin foil!! |
07-11-2016, 12:23 PM | #60 | |
