10-30-2010, 01:28 AM | #46 | |
10-30-2010, 03:56 AM | #47 | ||
200cc beast replica,carsoli cdi,performance coil,fmf powercore 2,uni air filter,hour/tach meter,jetted mikuni carb,msr bars,moose racing grips,yz250f clutch perch,D.I.D chain |
11-08-2010, 09:21 AM | #48 |
Since Pitster can't seem to give me a straight answer on getting the flywheel cover, it is back to "project: Project".
On a positive note (if there is one) it didn't break again the way I initially thought it did. The dog ear that broke off does NOT make contact with the rest of the block. Instead, the front chain/sprocket cover screws into IT which is a problem for two reasons. First, if you torque it down too tightly your bolt starts grinding on the block. And second it puts un-necessary pressure in an 'away from the block' fashion. Very poor design IMO. So, plan on a thread revival! There will be more pics. I think I'm going to take it to a machine shop and get it zapped. The new threads I created in the dog ear are holding very well. It only needs to handle about 6ft lbs for that cover. I'm also going to look at using the stud method and see if I can washer shim the negative pressure off of the assembly. Imagine with the bolt head sheared off. UGH - I just remembered I'm out of gasket paper :? Daddy 8) |
11-08-2010, 10:16 AM | #49 |
11-08-2010, 11:32 AM | #50 |
Yep, save your JB Weld.
11-08-2010, 12:15 PM | #51 | |
11-09-2010, 03:17 AM | #52 |
You can buy that part new 567571
(198750-001) It's $122.00 from Bike Bandit. http://www.bikebandit.com/houseofmot...62sch261#sch62 |
11-09-2010, 09:42 AM | #53 |
At least we know its available. The ebay one is half the price and a used cover is just as good. Quick coat of paint and its ready.
I believe the likelihood of it fitting is pretty high. The nx250 looks to be a good cross reference for parts. Just like the tw is for zongs. |
11-09-2010, 11:09 AM | #54 |
The bottom half of the engine does seem to be from a Honda 250, but you have to wonder about the top half since it’s a 400cc obviously not the same, is it just a ridiculously bored out 250? I think the 250 version that gets 25hp make much more sense then a 400cc that only gets 27hp. The XTR250 would it be the same engine top and bottom as the NX250 and not just half of it. The good thing is that the 250 lower case would not be over whelmed since the original Honda 250 it supported was rated for higher hp and torque then the 400. The big bore would explain the prioritization of the temperature gauge over the tachometer, I wonder how much bigger the case is over the original 250? It may just be a bored out 250 but that’s a big jump I would think they had to increase the case or the cylinder walls would be very thin.
I would think that Pitster should be able to provide a new cover and gasket for under $100.00 and either the XTR or Xingue part should fit it. The problem would be they likely would not stock them and they would have to order one from china and the price goes up then. |
11-09-2010, 12:05 PM | #55 | |
Happy to serve. |
11-09-2010, 12:22 PM | #56 | |
http://chinariders.net/modules.php?n...wtopic&t=10831 Spud
11-10-2010, 01:30 AM | #57 |
Spud, is that your observation, or did you find some data that pointed you in that direction? I'm asking because I'm an enthusiast, and I never would have thought of Rotax.
11-10-2010, 01:41 AM | #58 | |
11-10-2010, 02:29 AM | #59 |
That makes me wonder if the engine is actually 400cc. If the bottom end is stock XR250, the stroke is likely 59.5mm. If the cylinder is a stock Rotax 400, the bore is likely 91mm.
The formula I use is bore x bore x stroke x #of cylinders x 0.7854. That gives us 386981 cubic mm, or 386.98cc. Who knows.
11-10-2010, 03:01 AM | #60 |
When i ordered my bike about two years ago, they told me that motor has Rotax top end.
They also told that it is 387cc. |
